water loss
Guest david
Guest david
my radiator is loosing about a pint of water every week had a good look round and cant see any leaks have all so tried two different rad caps now i am at a loss any idears :search:
could be the dreaded head gasket, take it to a specialist that can test it
Guest david
need a little more than that?
does it overheat? any white smoke (steam) out of the exhaust? oil in the water or vice versa?
Have you looked around the matrix pipes, checked your passenger footwell?
no over heating/no white smoke and no white gunk under oil cap and foot well is bone dry it has me at a total loss each day just a Little goes bye the end of week about a pint has gone cant fined a thing had a good look round all pipes and water pump and looked for pin hols in rad
Guest david
OK had another look round and i think it might be a slight leak from the water pump could this be a new gasket if so how hard are they to change
