Guest swanzsupra Posted May 25, 2009 Share Posted May 25, 2009 Hi all need help. Have bad condensation in one of my plastic headlamps. The seal around the headlamp looks fine ? Also i have had a look at the top of the headlights and one of them has a littleclear round plastic cover in the middle of them, but the one with condenstion's cover is missing and when i look down where the cover is missing i can see water welling up ? Please help . Thanks . Quote Link to comment Share on other sites More sharing options...
Kirk Posted May 25, 2009 Share Posted May 25, 2009 Pull your headlamp out, unplug all your bulbs and drain it. Try and get a new cap or just cover it up for the time being Quote Link to comment Share on other sites More sharing options...
merckx Posted May 25, 2009 Share Posted May 25, 2009 I removed the bulbs and used a hot air gun (move the heat around so you don't melt it) on the lense to evaporate the condensation out of the headlamp. Quote Link to comment Share on other sites More sharing options...
Kirk Posted May 25, 2009 Share Posted May 25, 2009 be careful when using heat gun or you end up with a heat spot lile this Quote Link to comment Share on other sites More sharing options...
Guest swanzsupra Posted May 25, 2009 Share Posted May 25, 2009 ok thanks for your replies most appreciated . Quote Link to comment Share on other sites More sharing options...
alaing Posted May 25, 2009 Share Posted May 25, 2009 Another way is a towel over them with the headlamps on full beam but be careful can get quite hot! Quote Link to comment Share on other sites More sharing options...
Guest swanzsupra Posted May 26, 2009 Share Posted May 26, 2009 Condensation gone ! removed headlight bulb and used hairdryer to dry out headlamp , took about 25mins , was well worth it. Thanks for the ideas everyone. Quote Link to comment Share on other sites More sharing options...
Guest Suprafly Posted November 15, 2009 Share Posted November 15, 2009 I've got this same problem on my drivers side headlight, I thought about using a hairdryer to evaporate the condensation, and after a quick search (yes some people actually do use the search button) and this confirms that, thanks. Quote Link to comment Share on other sites More sharing options...
Guest Suprafly Posted November 15, 2009 Share Posted November 15, 2009 Right It took me all of 20 minutes with the wifes hairdryer to clear the condensation, I refitted my light bulbs and rubber grommet seals and all was well for about an hour, so I'm thinking there was obviously still some moisture present. Back out with the hairdryer tomorrow then. Quote Link to comment Share on other sites More sharing options...
