fizzle Posted May 24, 2009 Share Posted May 24, 2009 can anyone tell me where the fuse is for the electric windows? and also a wiring diagram if poss for the passenger side window switch... thanks... Link to comment Share on other sites More sharing options...
absz Posted May 24, 2009 Share Posted May 24, 2009 The fuse is N0 18 (30amp) drivers footwell. but also controls central locking so if thats working its not the fuse. also there is a relay numbered n02. the feed to the passeger side window is linked via the drivers side so you need to check wiring plug on the drivers side to make sure there is feed there. Link to comment Share on other sites More sharing options...
fizzle Posted May 25, 2009 Author Share Posted May 25, 2009 excellent thanks, any idea which wire goes where? the housing broke so just have 5 loose wires.. live, 2 ups and 2 downs i assume, tried to copy opposite side but has 2 rows not 1.. Link to comment Share on other sites More sharing options...
absz Posted May 25, 2009 Share Posted May 25, 2009 Here you go http://www.mkiv.com/manual/1995_electrical_manual/I/95elec_136.JPG http://www.mkiv.com/manual/1995_electrical_manual/I/95elec_137.JPG Link to comment Share on other sites More sharing options...
fizzle Posted May 26, 2009 Author Share Posted May 26, 2009 Thanks guys, i now have it wired correctly, but won't work, i checked the fuse and thats ok, what else can i try??? Link to comment Share on other sites More sharing options...
n boost Posted May 26, 2009 Share Posted May 26, 2009 The switch itself? I have a pair for sale if interested. Link to comment Share on other sites More sharing options...
fizzle Posted May 26, 2009 Author Share Posted May 26, 2009 possibly, but it doesnt work from either the drivers control or passenger side! do all the locks etc have to be connected as ell for it to work? Link to comment Share on other sites More sharing options...
RED_ROCKET Posted May 27, 2009 Share Posted May 27, 2009 hey bud if its the switches just have the ones back out the door card you gave us Link to comment Share on other sites More sharing options...
fizzle Posted May 27, 2009 Author Share Posted May 27, 2009 lol, gonna test it with david's switches tomorrow, see if it works.. will let u know, although i think drivers side is ok, its just the passensger one that f00ked!! Link to comment Share on other sites More sharing options...
RED_ROCKET Posted May 27, 2009 Share Posted May 27, 2009 cool hows it looking now then all finished Link to comment Share on other sites More sharing options...
fizzle Posted May 27, 2009 Author Share Posted May 27, 2009 finished tomorrow... epic delays!!! Link to comment Share on other sites More sharing options...
fizzle Posted May 28, 2009 Author Share Posted May 28, 2009 tested it with davids switches and works fine, think i fried the inside when i wired it wrong! so just need new passenger switch... anyone? Link to comment Share on other sites More sharing options...
