Windows switch help... asap!
fizzle
The fuse is N0 18 (30amp) drivers footwell. but also controls central locking so if thats working its not the fuse. also there is a relay numbered n02. the feed to the passeger side window is linked via the drivers side so you need to check wiring plug on the drivers side to make sure there is feed there.
