TurboBrett Posted May 26, 2009 Share Posted May 26, 2009 Subscribed !! Quote Link to comment Share on other sites More sharing options...
Kirk Posted May 27, 2009 Author Share Posted May 27, 2009 (edited) Right guys, all cosmetics are done now! heres the finished lenses and surrounds! They came out beautifully! pictures dont do them much justice! its a shame i couldnt save the rings though and i might end up painting the shiny piece below the low beam projector, i dunno yet though. I am gutted though about the drivers side lense, was hoping the heat spot would be less visable but unfortunatly not its not noticable until you get it into direct light. Idealy i could use another set of headlamps which are fully intact, all mounting points etc. Anyone got a spare set?? Next thing to do is begin the retrofit. Hopefully the projectors and ballasts should arrive this week Edited May 27, 2009 by Kirk (see edit history) Quote Link to comment Share on other sites More sharing options...
Kirk Posted May 27, 2009 Author Share Posted May 27, 2009 another pic.. will give some idea of what it will look like complete Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted June 30, 2009 Share Posted June 30, 2009 Look spot on. I need to get my plastic covers redone. I used 1500 last time and they yellowed up quite quickly. perhaps go down to 2500 this time. Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 30, 2009 Author Share Posted June 30, 2009 i suppose you could yeah, i prefer to flat all the yellow out of it then seal it with laquer, prevents it happening again Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted June 30, 2009 Share Posted June 30, 2009 and these ones you have just gone down to 1500 right? Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 30, 2009 Author Share Posted June 30, 2009 i acualy finished them with 1200, then before laquer 3000 them and end up with a smooth finish, its like glass Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted June 30, 2009 Share Posted June 30, 2009 cool, ill give that a go. Need to get some paper tomorrow Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 30, 2009 Author Share Posted June 30, 2009 its well worth it mate in the long run, it never needs doing again! aslong as is done proper it should never yellow! Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted June 30, 2009 Share Posted June 30, 2009 they dont look too bad with the 1500, need to get some 3000 tomorrow and ill get them done this week. Just the lenses that need doing now as I did the spraying of the inners last year Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 30, 2009 Author Share Posted June 30, 2009 you only need to clear the outside of the lense if you do so mike, just polish insides up a bit cant wait to see the old gal next month! Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted June 30, 2009 Share Posted June 30, 2009 you only need to clear the outside of the lense if you do so mike, just polish insides up a bit cant wait to see the old gal next month! Its the insides of mine that have yellowed from where its been done before so Ill have to do both sides Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 30, 2009 Author Share Posted June 30, 2009 oh dear... the j specs in this thread were yellowed, but bare in mind if 1 is cleared then it will be very unlikely to re yellow due to the UV protection properties in the clear Quote Link to comment Share on other sites More sharing options...
martini Posted June 30, 2009 Share Posted June 30, 2009 Is it the outside or inside that yellows most? i.e. could a bit of gentle sanding on the outside of mine sparkle them up a bit? Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 30, 2009 Author Share Posted June 30, 2009 outside is usualy the main issue, once they yellow the inners start to yellow. You can sand them back and polish them up but they will eventualy yellow again Quote Link to comment Share on other sites More sharing options...
martini Posted June 30, 2009 Share Posted June 30, 2009 outside is usualy the main issue, once they yellow the inners start to yellow. You can sand them back and polish them up but they will eventualy yellow again I might get them a little touch up with some sanding... they aren't too yellow. HID lights look nice anyway. Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted June 30, 2009 Share Posted June 30, 2009 well done mate, excellent job Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 30, 2009 Author Share Posted June 30, 2009 I might get them a little touch up with some sanding... they aren't too yellow. HID lights look nice anyway. keep watching this space! HID retro is on it way once i track down some cheap s2k headlamps or accord headlamps believe me the results are so much better than these P n P kits Quote Link to comment Share on other sites More sharing options...
martini Posted June 30, 2009 Share Posted June 30, 2009 Sounds good mate. Might sound like a dumb question, but which paint did you use to do the inside parts black? It looks great. I can imagine my dash having a touch-up with that. Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 30, 2009 Author Share Posted June 30, 2009 i just used a can of satin matt black Quote Link to comment Share on other sites More sharing options...
MarkR Posted June 30, 2009 Share Posted June 30, 2009 Nice writeup. Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 3, 2009 Share Posted November 3, 2009 Brill write up m8, what you using to seal them back up again? Quote Link to comment Share on other sites More sharing options...
Kirk Posted November 3, 2009 Author Share Posted November 3, 2009 (edited) sealed them back up AGES ago. I use 3/16 butyl tape or window sealer, cant remember which but i only use them to things Come to think of it i never quite finished this project... probly cause i gave up trying to find s2000 headlamps Edited November 3, 2009 by Kirk (see edit history) Quote Link to comment Share on other sites More sharing options...
