jhh1987 Posted May 22, 2009 Share Posted May 22, 2009 I was driving today and usually i leave the overdrive on but i was in an area were I needed to go a little faster so I turned overdrive off. About a minute after that my engine and warning light came on but the car was still running smoothly so I turned the overdrive back on to see what would happen. When I did the engine light was still on but after a while it turned off, but the overdrive O/D off light keeps flashing. And every time i turn off the overdrive, the engine light comes back on after about 30 seconds. Anyone knows what might be the problem? the car still runs smoothly. Quote Link to comment Share on other sites More sharing options...
jhh1987 Posted May 22, 2009 Author Share Posted May 22, 2009 I really need help, any info is appreciated. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 22, 2009 Share Posted May 22, 2009 you need to do a diagnostic test , you can do this yourself , if you search the forum ther are many threads that expalin how to do it , and then the code you find will tell you waht is causing ther light to come on Quote Link to comment Share on other sites More sharing options...
Supranature Posted May 22, 2009 Share Posted May 22, 2009 http://www.mkivsupra.net/vbb/showthread.php?t=12734&highlight=overdrive Quote Link to comment Share on other sites More sharing options...
jhh1987 Posted May 22, 2009 Author Share Posted May 22, 2009 thx, ill try to see Quote Link to comment Share on other sites More sharing options...
