liam1 Posted May 21, 2009 Share Posted May 21, 2009 changed all four discs and pads a few weeks ago to 3g grooved ones had the car straight back into the garage after i noticed drivers side rear disc was all burnt garage sorted it out or so i thought only had car out twice since it was fixed noticed today after a 15min drive discs is still extremely hot along with the alloy any ideas whats causing it. Quote Link to comment Share on other sites More sharing options...
paul mac Posted May 21, 2009 Share Posted May 21, 2009 changed all four discs and pads a few weeks ago to 3g grooved ones had the car straight back into the garage after i noticed drivers side rear disc was all burnt garage sorted it out or so i thought only had car out twice since it was fixed noticed today after a 15min drive discs is still extremely hot along with the alloy any ideas whats causing it. i would hazard a guess you have j-spec brakes and the caliper is siezed, very easy job to fix and diagnose, get another garage as the ones you have used are muppets, do a search as theres loads of stuff on this Quote Link to comment Share on other sites More sharing options...
liam1 Posted May 21, 2009 Author Share Posted May 21, 2009 i would hazard a guess you have j-spec brakes and the caliper is siezed, very easy job to fix and diagnose, get another garage as the ones you have used are muppets, do a search as theres loads of stuff on this mine are j spec will get another garage to have look at it cheers. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 21, 2009 Share Posted May 21, 2009 The caliper slider pins are probably seized up. The disc may be *uggered, as may be the pads, so check them out, too, they don't like getting mad hot with no interim cooling. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 21, 2009 Share Posted May 21, 2009 The caliper slider pins are probably seized up. The disc may be *uggered, as may be the pads, so check them out, too, they don't like getting mad hot with no interim cooling. This happened to my Jspec brakes, dry caliper slider, we lubed it up and it was fine Quote Link to comment Share on other sites More sharing options...
Homer Posted May 21, 2009 Share Posted May 21, 2009 This rear caliper issue is becoming more and more common as these cars get older. Quote Link to comment Share on other sites More sharing options...
