EdMorris Posted May 21, 2009 Share Posted May 21, 2009 Ok, so I've done a search and tried everything suggested in order to remove my rear brake discs. Wound the shoes in and also tried using two bolts in the small threaded holes (the bolts don't bite strongly enough and just lose grip). No joy whatsoever. I'm now at a loss and so any help would be appreciated. I don't want to use excessive force as this normally ends in tears and extra expense. As a note the offside is really binding even with the shoes wound in, but the other side is freely moving and still not budging. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted May 21, 2009 Share Posted May 21, 2009 Have you given them a gentle smack with a hammer? hit the hub part of the disc not the disc face itself, unless your replacing, should free up the inside Quote Link to comment Share on other sites More sharing options...
EdMorris Posted May 21, 2009 Author Share Posted May 21, 2009 Yeah I've tried that too, and yes I am replacing. I'll give it another go tomorrow. Nothings ever easy on this build Quote Link to comment Share on other sites More sharing options...
Steviekid Posted May 21, 2009 Share Posted May 21, 2009 and also tried using two bolts in the small threaded holes (the bolts don't bite strongly enough and just lose grip). Are you sure you've got the right size of bolts? It's a bigger thread than it looks. Mine were stuck on solid but came off no bother when I used this method. Quote Link to comment Share on other sites More sharing options...
JamesC Posted May 21, 2009 Share Posted May 21, 2009 Get some proper sized bolts sometimes can be quite tight and this gets them off straight away. Quote Link to comment Share on other sites More sharing options...
supra matt Posted May 21, 2009 Share Posted May 21, 2009 Put the two bolts in as tight as they will go then get a piece of wood and a hammer and hit the back of the disk turning it as you go mate , Quote Link to comment Share on other sites More sharing options...
EdMorris Posted May 21, 2009 Author Share Posted May 21, 2009 Some good suggestions there. I tried m6 and m8, too small and too big, so have just bought some m7, which don't seem to grip completely either. Maybe the m8 is actually right? I'll try again, thanks chaps. Quote Link to comment Share on other sites More sharing options...
supra matt Posted May 21, 2009 Share Posted May 21, 2009 What pitch of thread are you using mate fine or course ? Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 21, 2009 Share Posted May 21, 2009 Is the handbrake off? Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted May 21, 2009 Share Posted May 21, 2009 I'm sure I used standard M8 bolts, not fine pitch, when I took mine off. The bolts will be tight due to the crap in the threads. Quote Link to comment Share on other sites More sharing options...
merckx Posted May 21, 2009 Share Posted May 21, 2009 I'm sure I used standard M8 bolts As far as I remember that's what they are. Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 21, 2009 Share Posted May 21, 2009 Is the handbrake off? Thats what i was thinking, done it myself:d Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 21, 2009 Share Posted May 21, 2009 Thats what i was thinking, done it myself:d bash bash bash stupid f-ing bash bash -what's that -oops... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 21, 2009 Share Posted May 21, 2009 M8 x 1.25 pitch, the common M8 pitch. Plastic or alloy faced mallet, a GOOD belt from the back pad face and they should come free. Not ideal as it COULD bruise the hub bearings, but if nothing else works.... If you have oxy-acetylene available heating the hub face of the discs should free them, too. A blow lamp won't have enough ooomph. Quote Link to comment Share on other sites More sharing options...
movistar Posted May 21, 2009 Share Posted May 21, 2009 bash bash bash stupid f-ing bash bash -what's that -oops... Lol...excellent:) Tried hitting the front top leading edge (not the disc)where the shoes are under.....and have you slackened the shoes right off, bit of wd40 wouldnt be a bad idea either...oh copper hammer is best Quote Link to comment Share on other sites More sharing options...
EdMorris Posted May 22, 2009 Author Share Posted May 22, 2009 M8 x 1.25 pitch, the common M8 pitch. Plastic or alloy faced mallet, a GOOD belt from the back pad face and they should come free. Not ideal as it COULD bruise the hub bearings, but if nothing else works.... If you have oxy-acetylene available heating the hub face of the discs should free them, too. A blow lamp won't have enough ooomph. Hmm, I tried this exact size. I'll stop being a girl about it and try again, with judicious use of a soft face hammer. Cheers all. Quote Link to comment Share on other sites More sharing options...
EdMorris Posted May 22, 2009 Author Share Posted May 22, 2009 SUCCESS! Thanks again for the help chaps. Just waiting for new parts to arrive now, which should be here soon. Quote Link to comment Share on other sites More sharing options...
