Guest junior Posted May 21, 2009 Share Posted May 21, 2009 hi, bought a 94 supra 3.0 non turbo this week, not long after leaving an amber (!) symbol came on located on the rev counter. it came on when i go upto about 80mph, i pulled over a turned the ignition off and restarted but it was still there for a few more miles, from what ive found on the net its called a SERVICE REMINDER INDICATOR or MASTER WARNING LIGHT, can any1 please help thanks junior Quote Link to comment Share on other sites More sharing options...
The Raven Posted May 21, 2009 Share Posted May 21, 2009 (edited) Yup. Does the engine warning light come up top right? Make sure this lights up when you first turn on Then read up on how to check for fault codes and check yours for a code post up what number you get and we can go from there Read this and it will explain how to get the code from the car. http://www.mkivsupra.net/vbb/showthread.php?t=35920 Try not to panic most of these are simple speedo faults or other easy fixes. Edited May 21, 2009 by The Raven (see edit history) Quote Link to comment Share on other sites More sharing options...
alaing Posted May 21, 2009 Share Posted May 21, 2009 Brake fluid level most likely, the brake fluid level sensors are very sensitive so even if it looks full top it up a little more. But if this is not the case read the fault codes as above and get back to us. Quote Link to comment Share on other sites More sharing options...
dukenukem Posted May 21, 2009 Share Posted May 21, 2009 Have you got an aftermarket front bumper i.e. removed the auto spoiler at the front of the car which automatically drops down at 60mph? I have a Veilside front and get that warning light unless its switched off. Quote Link to comment Share on other sites More sharing options...
The Raven Posted May 21, 2009 Share Posted May 21, 2009 Have you got an aftermarket front bumper i.e. removed the auto spoiler at the front of the car which automatically drops down at 60mph? I have a Veilside front and get that warning light unless its switched off. A very good point! Quote Link to comment Share on other sites More sharing options...
stevie_b Posted May 21, 2009 Share Posted May 21, 2009 Have you got an aftermarket front bumper i.e. removed the auto spoiler at the front of the car which automatically drops down at 60mph? I have a Veilside front and get that warning light unless its switched off. I'm not sure if any of the NAs came with an active front spoiler. My guess is 1) your speedo is reading in kph (so 80 on the dial is actually 50mph ish), and more importantly 2) I'm *guessing* the ECU has logged a "code 42" error: a common fault which is triggered at about 50mph. It usually means your speed converter or odometer unit is flaky. Not a big problem. But... I'm jumping the gun here. Get the error codes and post up here what they are. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 21, 2009 Share Posted May 21, 2009 I'm not sure if any of the NAs came with an active front spoiler. Are they fast enough to warrant one? Quote Link to comment Share on other sites More sharing options...
stevie_b Posted May 21, 2009 Share Posted May 21, 2009 Are they fast enough to warrant one? How ruuude! Quote Link to comment Share on other sites More sharing options...
