Boost Trouble
markybhoy86
Got my jspec supra decat last week but the guys had fitted the restrictor ring at the wrong place ( near where the 2nd cat was), the boost was running about 1.4 so i never drove it heavy and got it moved to where it should have been today- its still overboosting at 1.1-1.2 its a boost logic exhaust 3" to 4" at 2nd decat the restrictor ring is one i got off Paul (2") how can i get the boost down?? do i get a smaller restrictor ring (1 3/4")?
i've got a boost controller etc but i know you can only turn boost up not down, so thats not much use right now lol
dont know the make of the boost gauge off the top of my head, i'll check when i get in the motor after work, can c 1.2 in 2nd gear, after i seen it i didnt take it above in any other gear....when it hits 1.2 the engine makes a weird sound as if its struggling and the red warning light comes on on the boost gauge and it wont pull anymore, if i ease off the 1.2 till the light goes off it will pull quite happily.
i thought 1.2 was excessive for a j-spec?
It doesnt have anything to do with it overboosting. But you need an uprated fuel pump if you start going over 1 bar
I think the first step should be fitting a smaller restrictor ring, then tweaking the boost up to the desired level with the controller
Edited by jacko (see edit history)
i removed the 2" RR today and had a 1.6" one made up ( 1.6" was the smallest punch they had) it brought the boost back down to normal so i turned it up with the boost controller to 1bar, seems to be alright so far. its going into a tunning place to get everything checked over AFR's etc.
at least thats me got one thing on the mend so far lol struggling with upper control arms-been on one side for 2 hours, gave up lol il try again 2moro when my back recovers lol
