abs fault
mellonman
hi people
have a intermitant fault with my abs
i have checked for error codes but was clear but abs light does come on when fault happends
engine light flashed constant but the o/d light flashed a code of 42 dont know if that means anything
what happends is when i brake and then ease off as slowing at very slow speeds the brake peddal seems to rumble under my foot and car seems to run on abit this will happen for a couple of times then the abs light will come on constant
would love any help as theres no point having a 400bhp car that cant stop:(
but is that where the code comes from the over drive indicator?
Over drive indicator? :blink:
You're wanting to know how you get the fault codes?
and where is this no 1 speed sensor?
Page 469 and on, this manual is for the US spec TT and NA, most of it will be the same as the J spec car. :search:
http://www.turbosupras.com/pdfs/JZA80%20TSRM/DI.pdf
Obtained from:
http://www.turbosupras.com/pages/pages/technical/jza80/a80tsrm.htm
Edited by merckx (see edit history)
