Help again
SupraTT2004
I have got 3 defi gauges and a control unit. Boost, Oil Temp, Oil Press.
I have a problem with the oil pressure gauge at the end of the wiring from the gauge there is a connector which obiovuly plugs into the control unit. Well the connector is buggered basically. she wont click back into the control unit and you can see the connector is not good. so I need a new one then I can solder the connections back in place.
Can anyone tell me where the hell I get one of those connectors from?
Thanks
