Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 just wondering what problems/noises/performance drops e.c.t. other people have had when 1 or both of there cats has bugger up on the stock TT exhaust system. thanks Link to comment Share on other sites More sharing options...
little num Posted May 19, 2009 Share Posted May 19, 2009 i used to do scrap cars and take the cats off as they were very valuble metals in them, but supra cats are metal so cant really see how they can break. Normal cats are like honey comb that cracks and breaks up but steel cant. Link to comment Share on other sites More sharing options...
Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 well there is something in between 1 and 2 cat (closer towards 2) that is rattling, and its a chunky rattle and there is def something in there i have checked all the brackets e.c.t. Link to comment Share on other sites More sharing options...
Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 and are they steel for J-spec Supras? Link to comment Share on other sites More sharing options...
Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 What about Rust Deteriorating them? Link to comment Share on other sites More sharing options...
supraGZaerotop Posted May 19, 2009 Share Posted May 19, 2009 i am currently looking into changing both my cats. already got the second cat off a 60k car, so whats that 30odd thousand miles. last year my supe only just got through the emissions. o2 sensor is toast i reakon, got car booked in 9am in the morning for mot, so we shall see. reason why i thought i may have something up with my exhaust/cats is first thing in the morning i can hear a sort of clicky/ticking rattle which is coming from the cat/turbo area, cannot hear anything under the bonnet only when i stick my head under by the driving front wheel, its only there for maybe few hundred yards, i think its maybe cats or an exhaust leak until the exhaust gets hot and expands. what you think? Link to comment Share on other sites More sharing options...
Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 i get the rattle on start up, then it goes away. but if i put my head under the car whilst i give it a few revs with my hand, i can hear the rattle directly behind number 2 cat facing towards number 1 cat. and when iam driving the car/turbos make a howling noise on boost and the car seems restricted. Supra Matt posted this as well in an earlier post of mine so maybe this is it. ""Hi mate 1) loose the cat if it's had it that could be your problem full stop as it will block your exhaust putting lots of strain on the turbo's as there will be lots of back pressure in the system! Very bad for engine and turbo . hence the sound the turbo's are getting strangled IE they trying to spin fast but when you come on boost they cant breath and all the gas that is trying to escape down the exhaust is pushed back though them very bad . 2 ) is your bov stock ? if it is wipe it off and see if you can blow though it ? if you can it's duff and needs replacing . Hope that made sense?"" Link to comment Share on other sites More sharing options...
mawby Posted May 19, 2009 Share Posted May 19, 2009 txt spk isn't allowed on these forums especially in technical. Moved to off topic. Link to comment Share on other sites More sharing options...
Alex Posted May 19, 2009 Share Posted May 19, 2009 txt spk isn't allowed on these forums especially in technical. Moved to off topic. Do I leave you to get the blame for the new title or not? Link to comment Share on other sites More sharing options...
Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 i don't really care, i just want to know what is wrong with my car and i thought any technical problems with a car I.E exhaust you could post in Technical. obviously its not technical enough for some ppl... Link to comment Share on other sites More sharing options...
stevie_b Posted May 19, 2009 Share Posted May 19, 2009 i don't really care, i just want to know what is wrong with my car and i thought any technical problems with a car I.E exhaust you could post in Technical. obviously its not technical enough for some F**Kwits Don't use textspeak, then people will be much more helpful. I read your first post before anyone else replied, but I couldn't really figure out what you were asking, so I didn't bother replying. Just trying to help now by pointing out why you aren't getting the help you want. Link to comment Share on other sites More sharing options...
Alex Posted May 19, 2009 Share Posted May 19, 2009 i don't really care, i just want to know what is wrong with my car and i thought any technical problems with a car I.E exhaust you could post in Technical. obviously its not technical enough for some ... No it's not the subject matter it was the lack of plain English. You maybe able to read your txt speak, but other can't and those are the people who are most likely to have the answer to your question. If you can't be bothered to write, why should anyone be bothered to read let alone answer. It's a forum rule you signed up to, so expect abuse (and then banning) if you don't obey it. Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 19, 2009 Share Posted May 19, 2009 Link to comment Share on other sites More sharing options...
Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 what do you mean buy text speak?? do you mean the using U instead of you?? and stuff like that? if thats the case then im sorry, i thought most people were up to date, and i had to shorten what i wanted to say to make it fit Link to comment Share on other sites More sharing options...
JustGav Posted May 19, 2009 Share Posted May 19, 2009 what do you mean buy text speak?? do you mean the using U instead of you?? and stuff like that? if thats the case then im sorry, i thought most people were up to date, and i had to shorten what i wanted to say to make it fit It isn't considered up to date, it is consider more of a devolution.. Link to comment Share on other sites More sharing options...
b_have Posted May 19, 2009 Share Posted May 19, 2009 what do you mean, buy text speak?? Priceless Link to comment Share on other sites More sharing options...
TRACIE_LOU Posted May 19, 2009 Share Posted May 19, 2009 what do you mean buy text speak?? do you mean the using U instead of you?? and stuff like that? if thats the case then im sorry, i thought most people were up to date, and i had to shorten what i wanted to say to make it fit Not a case of being upto date its just about writing properly, plain english thats all everyone one wants.. Don't take it personally! I still get picked up on capitals and such like! Link to comment Share on other sites More sharing options...
Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 either, wow, i wont use "text" speak anymore, i didn't know "Text" Speaking would upset people, all i want is to know is what is wrong with my car thats it, sorry if i upset someone by "text" Speaking. just a habbit Link to comment Share on other sites More sharing options...
Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 just writing that stuff above i had to edit it a few times because of it lol Link to comment Share on other sites More sharing options...
jamesmark Posted May 19, 2009 Share Posted May 19, 2009 More than likely just a loose heat shield. Link to comment Share on other sites More sharing options...
Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 This is the heat shield around the cat? because i checked the cats and there were no loose bits or rattles Link to comment Share on other sites More sharing options...
jamesmark Posted May 19, 2009 Share Posted May 19, 2009 They can also be attached to the car. Link to comment Share on other sites More sharing options...
Guest Dizzmystar Posted May 19, 2009 Share Posted May 19, 2009 i did have a mechanic go over it as well and he said it defiantly sounds like the cat itself. this is a perfect opportunity to get a new exhaust the legit way so i can buy pass it through the mrs. haha Link to comment Share on other sites More sharing options...
jamesmark Posted May 19, 2009 Share Posted May 19, 2009 Why not jack the car up and take the 2nd cat out to have a look inside? It is the easiest to get to. As long as the bolts come off ok it shouls not take anymore than an hour if not less. Link to comment Share on other sites More sharing options...
DamanC Posted May 19, 2009 Share Posted May 19, 2009 i thought most people were up to date, and i had to shorten what i wanted to say to make it fit See, thats the thing that get me. Text speaking f**kwits think they are in the right and everone else is behind the times Jizz - Why do you have to shorten your posts? There is no 160 character limit here Link to comment Share on other sites More sharing options...
