SupraGirlie Posted May 18, 2009 Share Posted May 18, 2009 (edited) Ever since I had a Greddy BCC fitted, my car has not been running like it should, for a start it still has a fuel cut at highish revs every time which is very annoying, it doesn't start well, and it doesn't feel as quick as it was, when I put my foot down the power just isn't there sometimes Any ideas? Edited May 18, 2009 by SupraGirlie (see edit history) Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 18, 2009 Share Posted May 18, 2009 Perhaps it wasn't fitted correctly? Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted May 18, 2009 Author Share Posted May 18, 2009 (edited) Perhaps it wasn't fitted correctly? But could it be the cause of the car not running properly, or just the fuel cut? Perhaps I should just take it back to AFR. Also it only had a service like 200 miles ago. Edited May 18, 2009 by SupraGirlie (see edit history) Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 18, 2009 Share Posted May 18, 2009 was it a new or used controller, could it be faulty Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted May 18, 2009 Author Share Posted May 18, 2009 was it a new or used controller, could it be faulty Brand new bought from a shop. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 18, 2009 Share Posted May 18, 2009 Sounds like you need to get it back to AFR to investigate to me Could be unrelated, maybe a coil pack problem Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 18, 2009 Share Posted May 18, 2009 But could it be the cause of the car not running properly, or just the fuel cut? Perhaps I should just take it back to AFR. Also it only had a service like 200 miles ago. I thought the BCC was supposde to eliminate fuel cut? Defintatley take it back. If you had something fitted and now your car is playing up then that's the first port of call. Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted May 18, 2009 Author Share Posted May 18, 2009 Yeah I was just hoping it was something more simple I could sort myself rather than driving it back to AFR. Quote Link to comment Share on other sites More sharing options...
Duffman Posted May 18, 2009 Share Posted May 18, 2009 The BCC will eliminate fuel cut up until what it has been set for. I'm having problems with my car running sh*t afetr my BCC was fitted incorrectly it's overfuelling like mad. I'm going to take mine to a specialist. Would advise you do the same Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 18, 2009 Share Posted May 18, 2009 The BCC will eliminate fuel cut up until what it has been set for. I'm having problems with my car running sh*t afetr my BCC was fitted incorrectly it's overfuelling like mad. I'm going to take mine to a specialist. Would advise you do the same Who fitted yours? You are correct that the BCC needs to be set correctly, but incorrect settings should really only effect the point at which fuel cut comes in. I remember years ago having to change the settings on my HKS FCD, and altered the settings dramatically in the first instance choose a starting point and the car barely moved. It got better as i changed the settings, but surely a tuning company can't get it THAT wrong? Quote Link to comment Share on other sites More sharing options...
DaveR Posted May 18, 2009 Share Posted May 18, 2009 It's definitely worth paying the money to get this sort of thing done properly - it can lead to all sorts of dramas if not. You don't want to end up with a knackered engine for the sake of needing to spend less than a ton on an hour's labour! Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 18, 2009 Share Posted May 18, 2009 To be fair she did take it to AFR who are more than competant so I wouldn't have said it was a problem with the installation. Nell, have you tried asking Matt or Dude? Could it be something like spark plugs? Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted May 18, 2009 Author Share Posted May 18, 2009 Who fitted yours? You are correct that the BCC needs to be set correctly, but incorrect settings should really only effect the point at which fuel cut comes in. I remember years ago having to change the settings on my HKS FCD, and altered the settings dramatically in the first instance choose a starting point and the car barely moved. It got better as i changed the settings, but surely a tuning company can't get it THAT wrong? When I went to the AFR open day, got on the Dyno and the fuel cut was there, so Matt changed some settings I believe, but it still made a poor power figure, and then when I drove it out of AFR that day, I started it up and it was like it was cold and poured with smoke and was over fuelling so badly, they fixed that on the spot, ever since then it's been running proper sh!t To be fair she did take it to AFR who are more than competant so I wouldn't have said it was a problem with the installation. Nell, have you tried asking Matt or Dude? Could it be something like spark plugs? I doubt it's spark plugs, I am positive it's do with the BCC now. Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 18, 2009 Share Posted May 18, 2009 When I went to the AFR open day, got on the Dyno and the fuel cut was there, so Matt changed some settings I believe, but it still made a poor power figure, and then when I drove it out of AFR that day, I started it up and it was like it was cold and poured with smoke and was over fuelling so badly, they fixed that on the spot, ever since then it's been running proper sh!t At which point did they fit the BCC? Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted May 18, 2009 Author Share Posted May 18, 2009 At which point did they fit the BCC? No more than I week I think, but I hardly drove it in between, I did notice it was running rich though right after it was fitted. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted May 18, 2009 Share Posted May 18, 2009 Whizz it back Nell, we'll get Dude to work his magic. The problem on the open day was the coolant temp sensor connector, so totally unrelated Quote Link to comment Share on other sites More sharing options...
