Oem trac ecu
AlanM
Sorry to point out the obvious. So this is the traction control ecu? where are they mounted as my traction does not work but i think i have found a box which has nothing plugged into it (on passanger side where your kneed would be roughly, to the side of the sterio) and also some wires not plugged into anything(under the passanger seat). but they are not next to each other!
