Guest toc Posted May 17, 2009 Share Posted May 17, 2009 Right lads I have noticed that when I go over a bump with BOTH rear wheels eg. a speed bump, I get a horrible clank across the back of the car. Its driving me crackers. My shocks were replaced so it isn't them. To be honest I can feel every bump on the road and Im fed up of it. Any advice greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Ian W Posted May 17, 2009 Share Posted May 17, 2009 Top mounts? I'd hazard a guess that if the shocks were replaced they simply put the old top mounts back on? Quote Link to comment Share on other sites More sharing options...
Guest toc Posted May 17, 2009 Share Posted May 17, 2009 Might sound stupid but I'm not great with suspension. Are the top mounts hard to replace. I really do feel every bump on the road. Quote Link to comment Share on other sites More sharing options...
Ian W Posted May 17, 2009 Share Posted May 17, 2009 Get someone to sit in the back and have a listen to try and ascertain if it's coming from the top mounts (i.e. right by their ears ) or lower down. Could be a number of things to be honest. Have the subframe bolts been tightened recently? Quote Link to comment Share on other sites More sharing options...
Guest toc Posted May 17, 2009 Share Posted May 17, 2009 No, Iv had the car a year and only replaced the rear shocks, never tightened any bolts. Torque spanner do the job with every bolt i can find? Quote Link to comment Share on other sites More sharing options...
Ian W Posted May 17, 2009 Share Posted May 17, 2009 Think you need to identify the subframe bolts and tighten them to the specific settings (though you'll need the car in the air to do this). That'd be the cheapest fix so I'd start there. After that I'd probably be looking at top mounts and bushes as possible culprits. Quote Link to comment Share on other sites More sharing options...
Guest toc Posted May 17, 2009 Share Posted May 17, 2009 Cheers man, thanks Quote Link to comment Share on other sites More sharing options...
ellis Posted May 17, 2009 Share Posted May 17, 2009 Rear subframe bolts? They can come loose and make a rattling noise. Quote Link to comment Share on other sites More sharing options...
Guest toc Posted May 17, 2009 Share Posted May 17, 2009 thanks a lot. Does the car need to be in the air? Quote Link to comment Share on other sites More sharing options...
Ian W Posted May 17, 2009 Share Posted May 17, 2009 Think you need to identify the subframe bolts and tighten them to the specific settings (though you'll need the car in the air to do this) thanks a lot. Does the car need to be in the air? Did you read my reply? LOL Quote Link to comment Share on other sites More sharing options...
Guest toc Posted May 17, 2009 Share Posted May 17, 2009 Oh right, ha ha. Thanks again Quote Link to comment Share on other sites More sharing options...
