Window Problem
toyotasuprauk
Had a nightmare time with my window today. It hasn't worked properly for ages needing a bang on the door card to get it working again.
I cleaned the motor out and it seems to be working but in error took apart the circular bit that the cables go into and just cant get it back together again right. Now it just seems to chew up the cables every time I try to move the window up or down then get stuck now they are getting damaged and frayed! I've got it sitting on wood at the moment to keep the window closed after I got very fed up with it.
I understand I just need the regulator not the entire unit but cant imagine fitting is going to be easy!
I've found a few posts on here but none with any instructions / tips on fitting.
Has anyone got any fitting guidelines, or if you have one for sale I might be interested before I try Steve Manley for a price.
Thanks.
Guest drlee
give keron a shout,he can sort you out with second hand complete,my mate dan got s,h complete regulator from him,i fitted it .it was spot on.d
