cheekymonkey Posted May 16, 2009 Share Posted May 16, 2009 If anyone got any footage of this outside the car (down by the Esses I think it is) then let me know! I seriously need to get on a skid pan now and practise controlling a slide as this is the second time it's happened. Doh! Quote Link to comment Share on other sites More sharing options...
Guest drlee Posted May 16, 2009 Share Posted May 16, 2009 what exactly is happenin mate?.d Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted May 16, 2009 Author Share Posted May 16, 2009 Well assuming the video is working it's just me spinning off the track at caste combe! Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 16, 2009 Share Posted May 16, 2009 lol, looks like you were a bit lucky not to be hit by that Scooby! Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted May 16, 2009 Author Share Posted May 16, 2009 Yes I only saw how close that was after looking at the video. Fresh pants! Quote Link to comment Share on other sites More sharing options...
wantasupra Posted May 16, 2009 Share Posted May 16, 2009 have a lookie here,some info may help. http://www.evo.co.uk/trackdays/circuitguide/235670/castle_combe_in_detail.html Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 16, 2009 Share Posted May 16, 2009 Sounds more like an inappropriate gear change, or clutch control to me, did you change down after turning in? Quote Link to comment Share on other sites More sharing options...
Ian W Posted May 16, 2009 Share Posted May 16, 2009 Sounds more like an inappropriate gear change, or clutch control to me, did you change down after turning in? Certainly sounded like you were changing gear mid-way through the chicane? Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted May 16, 2009 Author Share Posted May 16, 2009 You may have a point there Chris. I had been taking this corner in 2nd previously, but tried 3rd this time and may have tried to change back to 2nd half way through. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 16, 2009 Share Posted May 16, 2009 I think you did, which is perfectly OK, *IF* you are quick and smooth enough to match the revs perfectly to the road speed, and the cars' rear tyres aren't on the ragged limit of adhesion. When you let the clutch up I think you can hear the rev mismatch being taken up, which put extra torque through back tyres already on their traction circle limit. Try and get all the gear changes done in a straight line until you are confident you can multi task in a corner under stress This why autos are a PITA on track, they will change UP if you panic and lift a bit mid corner, so are best driven in manual mode. This is even more appropriate in the wet.... Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted May 16, 2009 Share Posted May 16, 2009 I so want to do a trackday now, once I get a set of stock 17's and a bit of suspension work done hopefully I'll get a go on a trackday before the end of the summer. I hate thrashing it on the road for fear of slipping up or getting caught out, trackdays look like a lot of fun though. How hard are they on your tyres and brakes? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 16, 2009 Share Posted May 16, 2009 Not TOO bad at first, but once you get up to speed you can have a rest home for dead discs, tyres and pads in your shed. Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 16, 2009 Share Posted May 16, 2009 How hard are they on your tyres and brakes? It will be hard on both, but for your first time out you should be ok with what you have if you keep the number of laps you do at a time low. Road tyres will overheat after a few laps (which you should feel) and then you will ruin/wear the tread significantly if you carry on. Likewise the brakes have more chance of fading the more laps you do. The more agressive/better/quicker you get and the longer you stay out for the more you need to think of track specific tyres/brakes/suspension. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted May 16, 2009 Author Share Posted May 16, 2009 Thanks Chris, it's all about learning and advice like yours is much appreciated Quote Link to comment Share on other sites More sharing options...
Professor Kenny Posted May 16, 2009 Share Posted May 16, 2009 That's pretty much the accident I had in my last Supe, except it was diesel on the road as I was accelerating out of a corner - caught the first slide, but the second one ended up in the barrier I've been thinking about some sort of track day/high performance training/something to get a bit of practise at that sort of stuff - could do with upping my confidence a bit too; last year's crash coupled with a bad head-on a couple of years ago has made me a bit nervous lately O_o Quote Link to comment Share on other sites More sharing options...
Chingy Posted May 16, 2009 Share Posted May 16, 2009 glad you had a bit of grass to run off to Quote Link to comment Share on other sites More sharing options...
bignum Posted May 17, 2009 Share Posted May 17, 2009 The 1st part of the slide wasn`t too bad but it looks like you over corrected the slide and didn`t get the lock off quick enough which is why it flicked you the other way, very easy mistake btw which ive done dozens of times:), i did a drift day at santa pod last year and found that useful with judging how much lock to get on and getting a feel for the back end, not sure i`d do another 1 though. Quote Link to comment Share on other sites More sharing options...
Kirk Posted May 17, 2009 Share Posted May 17, 2009 unlucky mate! ive done the same countless times so i took a proper course in car control... sorta fixed the problem but sayin that havnt done it for a while so i probly suck again! i was tought to get all your work done before the corner so your not correcting yourself through the corner which causes that! it comes with practice Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted May 17, 2009 Share Posted May 17, 2009 (edited) Sounds more like an inappropriate gear change, or clutch control to me, did you change down after turning in? How about somebody organising a beginners track day i would be up for it as would like a go on a track without getting in the way of the pros Edited May 17, 2009 by wile e coyote (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 17, 2009 Share Posted May 17, 2009 There are plenty of novice only track days around. MSV do quite a few. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 17, 2009 Share Posted May 17, 2009 How about somebody organising a beginners track day i would be up for it as would like a go on a track without getting in the way of the pros We have hired the drift circuit for Suprapod, it will be a good chance to get some practice on how you car performs under a slide in a safe environment. We are hoping to have some tuition available on the day too. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 17, 2009 Share Posted May 17, 2009 Just watched your whoops pt 1 video. You were lucky not to spank the armco on that one Quote Link to comment Share on other sites More sharing options...
edge Posted May 18, 2009 Share Posted May 18, 2009 I was up the bank watching when you came off. The scooby wasnt that close but i do remember you spinning round quite fast. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted May 18, 2009 Author Share Posted May 18, 2009 Just watched your whoops pt 1 video. You were lucky not to spank the armco on that one Hehe, yes, that one last year was somewhat worse! Definitely need more practise and instruction methinks. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted May 18, 2009 Author Share Posted May 18, 2009 We have hired the drift circuit for Suprapod, it will be a good chance to get some practice on how you car performs under a slide in a safe environment. We are hoping to have some tuition available on the day too. I'm going to Supra Pod but wasn't going to sign up for the drifting, as I don't want to eat tyres. I never thought of using it for practise in that way though, could be a good plan! Quote Link to comment Share on other sites More sharing options...
