People who've dropped to 17's
jevansio
I'd like to hear from people who have dropped from 18's to 17's in the interest of handling.
I've just dropped from 19's to 18's (dropping around 2.5kg per wheel) and the difference was pretty amazing.
I just want to know if I drop from 18's to 17's (again with 2.5kg per corner) will I get the same increase in performance/feel all over again.
I'm torn between dropping to lightweight 17's or 18's (both prolly around the same weight), I know the 17's won't look as good, but if it handles great I think I can live with it. If I won't notice the difference I'd rather just go with lightweight 18's.
i went back to 17"s for track days, and sometimes for normal driving the 19" felt better until i had the geo reset for 17"s one of the reasons i was going to keep the black one with stock wheels, great drive on 17"s when set up right;)
When I had my Supra's I also went from 19's to 18's and it was like night and day.
On my UK spec it came with 18's and I put OEM 17" wheels on and once again the difference was noticeable. I loved my Supra's handling with 17's on it. :)
Obviously my cars were only TT's and not lush single like yours.
How much do OEM 17's weigh? when i went from OEM 17's to 19's i never noticed much difference but then when i changed to lightweight 18's i noticed a huge improvement, maybe some super light 17's would be great:)
Thanks for the feedback guys.
I think with a single it's even more important to have a good wheel setup, my 19's always felt unsettled, Michel said so, & Ro did too. The 18's feel amazing. I just want reassurance before I ditch the TRDs that I'm making the right move :)
This is what I'm pondering, I want to know that given 17's & 18's that weigh the same (albeit lighter than my current 18's) will I be able to tell the difference between them, ie is it the weight I can feel or the weight combined with the size difference
If the 17" and 18" alloys really are the same weight then its probably worthing noting that the 17's tyre will be heavier than the 18's assuming the same widths are used and the 18's have the correct lower profile..............so all up weight of the 17's would be more than the 18's.
In regards to better handling, does the offset not also play a role too though?
Not as much as people make out imo, you dont see any racing cars sticking to stock offsets.:)
"waits for somebody to come along saying the suspension is set up for them wild offsets":blahblah:
Good point!
I've never had 19's on my cars, but the difference between 18's and 17's was significant, the car felt more settled and eaiser to control with the 17's. That said, the 18's were quite heavy.
The difference between the two sets was much greater with the single than the TT, mostly notably when exiting roadabouts.
That said, 17's don't look to good on a body kitted car.
I went from 19's with a medium poor offset to 18's with almost stock offset (clearance required some caliper moving) but the difference was very impressive. Miles more turn in, stability, and straight line grip with a smoother ride :)
Never tried 17's...
Never tried 17's...
I have to say that im not supprised, my car handled very strangley with them wheels, pulled about a lot with very little grip compared to my other 19's i was running at the time, might have been down to tyres, my others was on R888's.
