sdistc Posted December 15, 2009 Share Posted December 15, 2009 LOL! And it seems everybody is adding to it:p Well heres my 2 pennith, The J spec could be bought with practically any options, so there are an awful lot of J spec cars equipped with any, or most of the UK options, plus others that where not even in the UK options list. IBTL;) Really? I have never seen an early model J-spec RZ (which by definition was the top of the range for standard equipment) with 4 pot brakes. That's not to say it's impossible (especially if 93 UK spec had 4 pots) but in all the Supras in Australia (and I've seen, if only on the web, most of them) there isn't one that came like that from Japan. Link to comment Share on other sites More sharing options...
sdistc Posted December 15, 2009 Share Posted December 15, 2009 the radiator may be smaller on the facelift but it is made of aluminium and has a better cooling efficiency so it is not a downgrade. I beg to differ - my late model radiator couldn't cope with 15 psi on the 4294, but the borrowed early model coped fine. Link to comment Share on other sites More sharing options...
Thorin Posted December 15, 2009 Share Posted December 15, 2009 J-spec RZ (which by definition was the top of the range for standard equipment) Wrong again. Link to comment Share on other sites More sharing options...
James Posted December 15, 2009 Share Posted December 15, 2009 Really? I have never seen an early model J-spec RZ (which by definition was the top of the range for standard equipment) with 4 pot brakes. That's not to say it's impossible (especially if 93 UK spec had 4 pots) but in all the Supras in Australia (and I've seen, if only on the web, most of them) there isn't one that came like that from Japan. With regards to the "bigger" brakes the UK spec came with, the following models (+ year) of Supra had said brakes as a factory option:- 1993-1997 SZ 1994-1997 SZ-R 1994-1997 SZ-R Aerotop 1995-1997 RZ-S 1993-1995 RZ 1993-1996 GZ 1993-1994 GZ Aerotop 1997-2002 SZ 1997-2002 SZ-R 1997-1998 SZ-R Aerotop 1997-2002 RZ-S The 1995-1997 RZ and 1997-2002 RZ came with the same brakes as the UK spec as standard fit. All of the others are a factory option and - in my eyes - not modified as such as I consider that more of an aftermarket definition. All of the bolded examples are of which Thorin's car may fall into when stating "1994 J-Spec". Given that it is a 6 speed (RZ/RZ-S), it still complies as they are in said category. By all means rarer yes, but far from not plausible Link to comment Share on other sites More sharing options...
DSK Posted December 15, 2009 Share Posted December 15, 2009 Can't beat heated seats in this weather Link to comment Share on other sites More sharing options...
sdistc Posted December 15, 2009 Share Posted December 15, 2009 Wrong again. By all means rarer yes, but far from not plausible Well, I stand corrected. Never seen one, but there is the possibility it exists - which is obviously what Thorin has But as to the "RZ" concept - my understanding was that RZ-S had lower specifications, and RZ was all options as standard. Does RZ only mean 6 speed turbo, then? Link to comment Share on other sites More sharing options...
Thorin Posted December 15, 2009 Share Posted December 15, 2009 But as to the "RZ" concept - my understanding was that RZ-S had lower specifications, and RZ was all options as standard. Does RZ only mean 6 speed turbo, then? GZ was the higher spec'd model by default, but RZ or RZ-S could be specced up the same anyway. http://www.mkivsupra.net/vbb/showthread.php?t=59334 Link to comment Share on other sites More sharing options...
sdistc Posted December 15, 2009 Share Posted December 15, 2009 Can't open PDF at work at the moment. Thanks for the link anyhoo Link to comment Share on other sites More sharing options...
hp006 Posted December 15, 2009 Share Posted December 15, 2009 What happens when you have a cross breed then? UK engine with jap body Link to comment Share on other sites More sharing options...
Thorin Posted December 15, 2009 Share Posted December 15, 2009 What happens when you have a cross breed then? UK engine with jap body It starts listening to Death Metal and worshiping Satan. Link to comment Share on other sites More sharing options...
James Posted December 15, 2009 Share Posted December 15, 2009 It starts listening to Death Metal and worshiping Satan. I need this cross breed car in my life now in that case. Link to comment Share on other sites More sharing options...
dr_jekyll Posted December 15, 2009 Share Posted December 15, 2009 from what i have gatherd the jspec was designed as a sprinter .a harder sprots car and the euro, uk and us specs were desingned as gt tourers, quieter nicer place to be. Link to comment Share on other sites More sharing options...
marcAB10 Posted December 15, 2009 Share Posted December 15, 2009 I need this cross breed car in my life now in that case. like you could listen to death metal anymore than you allready do!! of course you could catch up a little in your Satan worship I guess.. Pfft.. Bloody slacker. Link to comment Share on other sites More sharing options...
Abz Posted December 15, 2009 Share Posted December 15, 2009 280BHP on J-Spec? Mine managed 352BHP with no cats! When I was researching between the 2, I found the UK ones cost more (could be because they were more rare?) Performance wise not much difference, they both have pro's & con's. The facelift IMO do look just as nice as UK infact I think it looks nicer than a UK Spec. Link to comment Share on other sites More sharing options...
James Posted December 15, 2009 Share Posted December 15, 2009 like you could listen to death metal anymore than you allready do!! of course you could catch up a little in your Satan worship I guess.. Pfft.. Bloody slacker. I think I maybe already listen to slightly too much Link to comment Share on other sites More sharing options...
sdistc Posted December 15, 2009 Share Posted December 15, 2009 (edited) GZ was the higher spec'd model by default, but RZ or RZ-S could be specced up the same anyway. http://www.mkivsupra.net/vbb/showthread.php?t=59334 Had a quick squizz at the link - and while it is pretty clear about most things in contention, it doesn't make any indication about diff size, driveshaft size, and radiator size. Nor does it show the V161 change to late model VVTi Supes. Perhaps this would be useful information to add to the PDF? While it seems that owners *could* up-spec their cars, in my experience there are very very few that actually did. Edited December 15, 2009 by sdistc clarification (see edit history) Link to comment Share on other sites More sharing options...
sdistc Posted December 15, 2009 Share Posted December 15, 2009 However, given that the friendly argument today has given me the appropriate slap to the back of the head, I have decided to be a bit more scientific than "my experience". With this in mind, I started a poll on the SF.com.au forum to see how many 93-97 model Supras have 4 vs 2 pot brakes - seeing as Australia is exclusively JDM model. Link to comment Share on other sites More sharing options...
Guest Brian Mallon Posted December 19, 2009 Share Posted December 19, 2009 I beg to differ - my late model radiator couldn't cope with 15 psi on the 4294, but the borrowed early model coped fine. i found the radiator efficency for you radiator heat transfer.. copper 82.7kw/h copper(auto) 87.9Kw/h (Aluminium -96/4+) 92.0 kw/h from http://www.mkivsupra.org.nz Link to comment Share on other sites More sharing options...
Guest Brian Mallon Posted December 19, 2009 Share Posted December 19, 2009 i found the radiator efficency for you radiator heat transfer.. copper 82.7kw/h copper(auto) 87.9Kw/h (Aluminium -96/4+) 92.0 kw/h from http://mkiv.supras.org.nz/specs.htm The facelift aluminium radiator is not a downgrade. Link to comment Share on other sites More sharing options...
sdistc Posted December 19, 2009 Share Posted December 19, 2009 At the risk of inciting another argument, believe what you will about the ability of the late model aluminium radiator to cope with the heat produced by a single turbo. I and a number of the other 97+ 67mm+ singles found that a larger capacity radiator (for me, the early model was a temporary fix while PWR was on back order) was better able to keep temperatures down in normal and hot (25+ degrees) weather. As far as I'm concerned, if you drastically increase the heat generating capacity of the engine this should be countered by increased cooling capacity. This is more pronounced with the smaller capacity later model radiators - which may be more efficient, but simply don't have the capacity to deal with rapid changes in coolant temperature. Link to comment Share on other sites More sharing options...
