E-manage wiring diagram
madmarf
First issue you have, the NA won't use the ignition side because it runs on a dizzy. So you will simply need the injector side. There are a few wiring diagrams for the NA about which will give you the ECU pin outs.
If memory serves me right (and it may not :)), I believe the emanage ultimate had the ability to convert dizzy systems to coil packs, but I'm not sure if anyone actually used that function in the end.
The wiring that you would use includes, maf/map sensor, injectors and power....
nice one buddy, thanks for that. however i knew all that already lol. all i was after was the wireing diagram from the manual for the injector harness but was after ignition incase it needed running anywhere for signals. :D
I had this in my old files, I believe it is correct but not checked/used it for yonks...
I'm not sure, but you might able to use a single ignition wire as there is one coming off the ECU, it might allow you to retard/advance the timing via the emanage, BUTTTTT I'm not sure on this point.
i cant seem to match them :S
