barneybrendan Posted May 15, 2009 Share Posted May 15, 2009 trying to remove the brake servo.how does the steady bar inside the car come off,undone the nut that holds servo end.but the one above the column is now doing my head in.any advice Quote Link to comment Share on other sites More sharing options...
Rich8v Posted May 16, 2009 Share Posted May 16, 2009 you will have to drop the steering column. Remove the trim under the column. There is a screw one end. Then remove the pipe for the air vent. There are four black nuts holding the column up. Quote Link to comment Share on other sites More sharing options...
