halllon Posted May 15, 2009 Share Posted May 15, 2009 Dear guys, We are doing a custom map and we want the better duration of the non-turbo 2JZ-GE camshafts, and plan to mount such a set on the VVTi 2JZ-GTE twin-turbo head. We are ditching the VVTi system. Do the non-turbo camshafts physically fit the VVTi head? I know the non-VVTI GTE camshafts fit the VVTi head if you carve out a minor slot, but essentially what I am asking is whether the non-turbo GE camshafts differ from the turbo non-VVTi GTE camshafts. All answers appreciated - thanks in advance! Link to comment Share on other sites More sharing options...
JustGav Posted May 15, 2009 Share Posted May 15, 2009 The GE ones will have a dizzy key, I wouldn't have thought they would fit the 2jz-gte vvti head, however without physically matching them up I don't know. Link to comment Share on other sites More sharing options...
halllon Posted May 15, 2009 Author Share Posted May 15, 2009 The GE engine has a camshaft driven distributor. Does this interfere when the camshaft is mounted in a VVTi GTE head? Link to comment Share on other sites More sharing options...
halllon Posted May 15, 2009 Author Share Posted May 15, 2009 Thanks JustGav, I didn't notice your post prior to replying. It would be interesting to see a pic of the camshafts for measurement. Anyone? Link to comment Share on other sites More sharing options...
Wez Posted May 15, 2009 Share Posted May 15, 2009 Why are you ditching the VVTi, when setup properly its shows to give very nice gains in the lower to midrange areas Link to comment Share on other sites More sharing options...
JustGav Posted May 15, 2009 Share Posted May 15, 2009 (edited) I have got a set of ge cams in the shed, if you want me to go take some measurements. I'm still a little unsure why you would want to use the ge cams though, it surely would make more sense to use an aftermarket gte cam with a suitable profile. Loosing the vvti I can understand to make it easier to map and all that BUT wouldn't recommend it. I know the GE and GTE heads are different with regards exhaust ports, does this perhaps also translate to valve positions in which case the ge cams wouldn't fit anyway. Edited May 15, 2009 by JustGav (see edit history) Link to comment Share on other sites More sharing options...
halllon Posted May 20, 2009 Author Share Posted May 20, 2009 Actually we ended up using the stock VVTi system. The latest Autronic SM4 firmware is compatible with the VVTi solenoid. Results: 455 whp and over 600nm at the wheels and a very healthy midrange torque graph. Injectors are maxed though, running 4.5 bar fuel pressure and 94% duty cycle (stock grey 2JZ non-VVTi injectors). On topic: I noticed the twin turbo ex cams have the distributor key in them - surely they would fit the GE head? Link to comment Share on other sites More sharing options...
halllon Posted May 20, 2009 Author Share Posted May 20, 2009 BTW: These numbers are on E85, which - allegedly - cools the ceramic exhaust wheels... Link to comment Share on other sites More sharing options...
