Best way to unbolt the first cat
themodifiedkid
Jacked up my car earlier in the hope of changing the first cat to a de cat. WTF when i got under and had a look the 3 bolts are near impossible to get to unless you have the right tools. I know ideally it should be up on a ramp but at the mo its out of the question and it doesn't really bother me working under the car.
Anyway whats the best tools to get to these and is there any parts under the car i can unbolt and move temporary to make easier access to the first cats bolts. Tools wise Im thinking v long extension bar as I tried with a 10" and wasn't quick long enough so maybe 12"-15".
If anyone has done this could they please give me some pointers/tips to how the best way they done it.:search:
Cheers people, much appreciated :D
I think it's another one of those jobs where you eventually work out the best combination of wrenches and extension bars after much tears and sweating.
I found replacing the thermostat was like that - it took me about an hour to figure out how to combine my tools to get the bolts off, then 5 mins to do the job!
Yeah i know what you mean mate, I was thinking by posting up for advice would help cut down the above mentioned tears and sweating lol.....:p:sly:
Much plus gas and a decent socket set.
Dont attempt to shock them off, use gentle leverage.
Done several on the drive, not used ramps yet
And good luck :)
Excellent cheers mate, im assuming plus gas is like wd40(a penetrating oil/fluid) Also what did you end up using, was it a long extension bar, and did you move anything out the way for easier access, also sorry for all the questions but did you find removing the cat metal protective housing make it any easier to get the tools in there. :rolleyes:;)
Plus gas is a penetrating oil, WD-40 is just a water dispersant :)
Not really anything to move.
Some you can access just with a straight extension, some need a U/J in too. Best thing is to get a decent socket set together - most jobs on the Supra are made many times easier with decent tools.
when swapping mine I used a couple of extension bars and a universal joint: one of the nuts is particularly hard to get to without one of these. was pretty tough to undo even with it on a ramp... how high have you got it off the ground?
d'oh just seen robs post... ;)
Yes,that's all you need - long extension bars and the universal joint.
Two of them are easy enough to get at and one is a little awkward.
I find a couple of wobble extension bars are much better than universal joints. They don't break, and are easier to guide into position because they don't flop over completely.
Here you go:
http://www.machinemart.co.uk/shop/product/details/pro171
EDIT: In fact these are the ones I was meaning:
http://www.machinemart.co.uk/shop/product/details/pro-55-5-pce-1-2in-drive-ext-wobble-b
Edited by SimonB
Link added (see edit history)
