Guest okley_78 Posted May 13, 2009 Share Posted May 13, 2009 im have bot a úsed Greddy t78 that has one bin200mil and now when im start up the turbine dont spinn on idling but so fast im give it som gas it spinns up ???what is that the impeller feels just normal no silets of som thing it feels good .. What is the classic for judge a bad turbo? im thinks its even trow out some oil i bearings but it can was befor im start up im filled the turbo whit oil and im probably spild some oil on it but it feels that its never end smoking round the turbo???weard it only has ben trouble whit my conv Quote Link to comment Share on other sites More sharing options...
Dave17 Posted May 13, 2009 Share Posted May 13, 2009 Its not supposed to spin on idle? Quote Link to comment Share on other sites More sharing options...
Guest okley_78 Posted May 13, 2009 Share Posted May 13, 2009 strange all other turbos i have seen has do it Quote Link to comment Share on other sites More sharing options...
Dave17 Posted May 13, 2009 Share Posted May 13, 2009 Your saying you want your turbo to produce boost on idle? Or are you saying the turbine doesnt spin at all even when turned off? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 13, 2009 Share Posted May 13, 2009 My GT4088 doesn't spin on cold start, but once hot it will spin slowly, i would say its nothing to worry about, unless you have a lot of play of course. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted May 13, 2009 Share Posted May 13, 2009 It probably wont start spinning til about 6000rpm, then punt you into the bushes, i wouldnt worry about it. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 13, 2009 Share Posted May 13, 2009 All turbo's I've seen spin pretty darn quick when the car is idling, maybe because it's big old tractor technology it's just to darn large to get any movement on idle? Seems pretty odd though. Quote Link to comment Share on other sites More sharing options...
Rich Posted May 13, 2009 Share Posted May 13, 2009 My old T78 span on idle,so yours should! Quote Link to comment Share on other sites More sharing options...
Dave222 Posted May 13, 2009 Share Posted May 13, 2009 So does mine, doesn't produce any pressure but should turn at tickover. Quote Link to comment Share on other sites More sharing options...
supspower Posted May 14, 2009 Share Posted May 14, 2009 How does the car drive, does it hit boost properly? Quote Link to comment Share on other sites More sharing options...
Guest okley_78 Posted May 14, 2009 Share Posted May 14, 2009 im dont wont to drive the car when im se that the impeller stand still ,, Quote Link to comment Share on other sites More sharing options...
Alex Posted May 14, 2009 Share Posted May 14, 2009 With the engine off, spin it with your finger, it should move relatively easily although not frictionlessly. If it doesn't chances are it's in need of a rebuild. The other thing to do is get someone to step on the accelerator and rev the engine whilst you watch the compressor. If it doesn't budge with a few '000 rpm through it then it's deffo buggered. Quote Link to comment Share on other sites More sharing options...
Guest okley_78 Posted May 14, 2009 Share Posted May 14, 2009 its feel full normal when im spin it whit my finger .and as qickly im give the engine very lite rpm its start to spinn Quote Link to comment Share on other sites More sharing options...
Rich Posted May 14, 2009 Share Posted May 14, 2009 Pull the oil feed to the turbo off and crank the engine with the ignitor pack disconnected.Do this to make sure you are actually getting an oil supply to the turbo. Quote Link to comment Share on other sites More sharing options...
Alex Posted May 14, 2009 Share Posted May 14, 2009 its feel full normal when im spin it whit my finger .and as qickly im give the engine very lite rpm its start to spinn How much use has the car had? It may just need a low speed run around - getting fully warm etc to circulate some oil. Quote Link to comment Share on other sites More sharing options...
TLicense Posted May 14, 2009 Share Posted May 14, 2009 As has been said, get the engine up to temperature then whilst watching the compressor blades give the engine a blip. It should start spinning at some point. Watch it as it slows down, it should slow quite smoothly. If it suddenly just stops then it will need a rebuild. Quote Link to comment Share on other sites More sharing options...
