Positive Gold Audio Battery Terminal
Scott
Got a brand new battery terminal. I took it out of the packet only to notice that its positive and i need a negative one. I have already used a positive one and its a cracking terminal, takes 2 large cables (4 gauge i think) and a smaller cable (8 gauge)
Only after a tenner all in.
I have attached a pic of the item. If you want to see the ACTUAL item just let me know. As i said, its brand new, its only been taken out of the packet. It still has the little plastic bits in the connectors.
Cheers
Does it fit the small J Spec battery terminals?
No idea buddy, i got a new battery out of halfords. Its the code designed for the supra though if that helps.
Are the UK ones bigger than the J-Spec ones? What size are postive J-Spec terminals? I can measure the clamp.
  • 2 weeks later...
I know that the positive terminal is larger than the negative terminal (hence why this one is for sale). Do you know what size the terminal is on a J-Spec battery? I'll go get it just now and measure it.
ill have it, will sort out paypal tomorrow as im getting up early and need to go bed.
Regards
T
No worries, sold :)
I'll PM you payment details.
Out of curiosity, did you check the size?
