Guest okley_78 Posted May 13, 2009 Share Posted May 13, 2009 hallå evrybody im have doing a singel convers on my mikv and im have ben rekomend to use 2 fuelpumps and now im wonder can i use 2 pumps on the Oginal fuel line ??or do im have too have a fuel line extraa if so how to plugg in one more in standard fuel line?? Quote Link to comment Share on other sites More sharing options...
Jake Posted May 13, 2009 Share Posted May 13, 2009 One fuel line is fine for dual pumps. Why do you want/need more than one fuel pump though? Are you running in excess of 600 hp? Quote Link to comment Share on other sites More sharing options...
Guest okley_78 Posted May 13, 2009 Share Posted May 13, 2009 yes im think a 500-600hk but im want to bee safe but can im use 2 on orginal fuel line or is it to smal Quote Link to comment Share on other sites More sharing options...
Guest okley_78 Posted May 13, 2009 Share Posted May 13, 2009 pleas help and guide me to get a fine fuel setup for my singel im have a greddy t-78 and 650cc sard in orginal fuelrail ,Aem Ems,Hks Dli,and AEM AFR gauges,and one Walbro pump intank and im have order one more, Quote Link to comment Share on other sites More sharing options...
Terminator Posted May 13, 2009 Share Posted May 13, 2009 If you are looking to keep things safe and possibly going further with injector size, I would use the stock line for return and run a -8 line from the pumps splitting to a Y connector to feed both ends of the rail. You may wish to consider a larger bore fuel rail to make feeding the injectors from both ends of the rail easier and take the return from the centre of the rail. Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted May 13, 2009 Share Posted May 13, 2009 Buy a proper fuel kit, like PHR, and know you have done it right. or if you must make your own copy the spec from the http://www.powerhouseracing.com web site, as they are well tried and tested. Quote Link to comment Share on other sites More sharing options...
