Pilot Bearing
Guest llewelyn
Guest llewelyn
ok replacing clutch myself all stripped down just two questions on an 93 manual non turbo pilot bearing inside flywheel correct?
and how would i replace this with out right tool?
Yep its in the middle of the flywheel.
Remove it by packing a load of grease into it, then you will need to find something that will fit into it nicely, maybe a ratchet extension bar! Tap it in, the grease should compress and push the bearing out. You may need a fair amount of grease! ;)
  • 7 months later...
Just want to add: a 3/8" extension bar is just too big to fit in the inner race of the bearing. However, the pin that fits into the clutch release fork (once cleaned up!) on a 6-speed is just right for the job.
Takes a while to get all the air out of the cavity behind the bearing but once it's purged, the bearing pops right out with a gentle tap.
