Warning light flashing up
GeordieSteve
Just took the Sup for a quick run around the block before it's MOT tomorrow. Back in November I had the following mods:
Veilside cat back
Double de-cat with restrictor ring
Apexi Power air filter
NGK BKR7E's
Boost controller
TRL FCD
Now when I put my boot down, now and again the warning light would come on the dash for a second then go out. Strange I thought... then I blew a turbo! I thought it must have been a warning that my turbos were on the way out so left it as that. Now I've added:
Hybrids
Walbro fuel pump
FMIC
S-AFC II
(Injectors etc. being put in tomorrow and I've turned the boost controller off)
Now I'm STILL getting that light coming on :( Anyone got any ideas? It's all away to be mapped at the same time so no doubt the guy will come up with a solution but I'm just a bit nervous what it could be :violin:
Brake fluid level. Has to be pretty exact ive heard. So when you boot it, the fluid sloshes about and goes below the min' level.
Exactly what I thought.
Loads of people have posted up about this & pretty much every single one has been low brake fluid. Shame there couldn't be different lights like some of the newer cars.
