madmarf Posted May 12, 2009 Share Posted May 12, 2009 hey all, can anyone tell me the tilt degree on full throttle of the JZA80 n\a engine. ?? jez Quote Link to comment Share on other sites More sharing options...
TurboBrett Posted May 12, 2009 Share Posted May 12, 2009 what's tilt degree? never herd of it before Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 12, 2009 Share Posted May 12, 2009 Depends how worn your engine mounts are;) Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 12, 2009 Share Posted May 12, 2009 Hold on, I assume this is for the supercharger... surely you aren't thinking of mounting it on a chassis leg/body panel rather than the engine itself, the amount of play would be crazy.. Quote Link to comment Share on other sites More sharing options...
madmarf Posted May 12, 2009 Author Share Posted May 12, 2009 some keep saying its a problem, however if i did do it then TRUST ME it would be fine as long as the spring mounts were matched to the tild degree. however im not doing that now lol. found a way to mount up on the block that i so blindly missed Quote Link to comment Share on other sites More sharing options...
TurboBrett Posted May 12, 2009 Share Posted May 12, 2009 lol i completely missed the obvious, mount it to the block dont be silly!!! Quote Link to comment Share on other sites More sharing options...
madmarf Posted May 12, 2009 Author Share Posted May 12, 2009 right lets clear this up. a car engine (lets say the jza80) tilts to a maximum of 4 degrees on the standard mounts. therefore if you mount the supercharger to the body it will eventualy snap the belt, or even the SC head. now, if you make spring mounts for the SC attached to the body, the spring takes up 9 degrees of movement in all directions, therefore with that and the adjuster taking it all up you would NOT have a problem guaranteed (if fitted correctly). i am not fitting it to the body now i am fitting it to the block, i am ALSO heat wrapping the exhaust with 1200 degree temp wrap, i used this stuff also in the army and trust me it works. that will keep the heat away from the charger, and then the intercooler will do the rest. Quote Link to comment Share on other sites More sharing options...
Homer Posted May 12, 2009 Share Posted May 12, 2009 It wouldn't work like that though, the engine moves and vibrate when not under load or under light load (e.g. breaking traction in 1st gear will oscilate the engine quick side to side, it'd lose tension and spring off. I cannot understand how you would have ever got this to work, unless using solid engine mounts, even then it'd be a risk. But as you're doing things the right way now it's a bit of a moot point. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 12, 2009 Share Posted May 12, 2009 It wouldn't work like that though, the engine moves and vibrate when not under load or under light load (e.g. breaking traction in 1st gear will oscilate the engine quick side to side, it'd lose tension and spring off. I cannot understand how you would have ever got this to work, unless using solid engine mounts, even then it'd be a risk. But as you're doing things the right way now it's a bit of a moot point. Exactly! just a few of the fairly obvious reasons that i commented on in your other post, i admire your enthusiasm, but i think you need to give it some more thought and sound engineering practise. Even with the spring/shock mountings apart from what Homer has mentioned, the very fact that it can move in all directions is going to give you very iffy drive, and you will constantly suffer from belt slip. Anyway I'm glad you have found a way to mount it to the block, i hope the link gave you some good ideas, as the guy who is doing the build know his stuff;) Quote Link to comment Share on other sites More sharing options...
