6 speed clutch fork and other manual parts
keron
as above..need the clutch fork and bracket that bolts to the box. mines got a os one with after market fork so need to put it back to stock...anyone?
also need a clutch resiviour/cylinder
pedal box (clutch and brake)
manual gear surround
6 speed flywheel (just sold one as well...typical!!!) (located)
release bearing
asap please...thank you
I'm replacing all my clutch actuation parts (fork, hub, snap rings, bearings, wave spring etc) very soon when I fit my RPS clutch. I have no reason to believe the existing stuff is worn but wanted no ambiguity regarding the RPS clutch being affected by old parts. If you're still looking when I fit it all I'll give you a shout (should be within next 10 days).
