Tricky-Ricky Posted May 10, 2009 Share Posted May 10, 2009 Recently took a feed off the output to injector 1 from my EMU and configured it to log duty cycle, but i am rather concerned that some of the readings are low considering it at full boost? Going to have to check it against the EMU to be sure but i can't see why it would be wrong, for example I'm seeing only 34% DC at 15.7 PSI with an AFR reading of 11.04 on 540cc injectors? so I'm a bit baffled. Quote Link to comment Share on other sites More sharing options...
Wez Posted May 10, 2009 Share Posted May 10, 2009 Could it be that you are only seeing the correction value rather than actual duty? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 10, 2009 Author Share Posted May 10, 2009 Could it be that you are only seeing the correction value rather than actual duty? It will be the corrected duty cycle, but it is a total figure, same as the injector sees. Quote Link to comment Share on other sites More sharing options...
