Tourniquet Posted May 10, 2009 Share Posted May 10, 2009 Just had some fiddling done at my local tuner and now the air con's dead - is it likely to be a fuse or something > Haven't looked yet just thought I'd be lazy n see if it's a common problem easily sorted Quote Link to comment Share on other sites More sharing options...
Ian W Posted May 10, 2009 Share Posted May 10, 2009 You'll need to be a bit more specific. Is the air con pump just not engaging or is the whole heater panel not working? What 'fiddling' was done? Quote Link to comment Share on other sites More sharing options...
L18msy Posted May 10, 2009 Share Posted May 10, 2009 You'll need to be a bit more specific. Is the air con pump just not engaging or is the whole heater panel not working? What 'fiddling' was done? Could be a number of things, might need re-gassed, a blown fuse, a plug left off the pressure switch etc Quote Link to comment Share on other sites More sharing options...
Tourniquet Posted May 10, 2009 Author Share Posted May 10, 2009 They took out my wiring loom for an old turbo timer and tidied up the mess in the panel under the steering column. It blows ok and when i turned the heating on full and switched it straight to max a/c on the climate control it kicked in extra to cool it down but just doesnt blow cold a/c air, just like a normal crap fan on a non a/c car Quote Link to comment Share on other sites More sharing options...
L18msy Posted May 10, 2009 Share Posted May 10, 2009 Sounds as if it might need re-gassed. If it is still kicking in then it is still getting power to it, so i dont think the wiring tidy up has affected it. If there is little gas in the system it wont work to its full potential. Quote Link to comment Share on other sites More sharing options...
hogmaw Posted May 10, 2009 Share Posted May 10, 2009 Subscribed, I have this problem too, regassed it just last Sept and now I need to use it it's not blowing cold air Quote Link to comment Share on other sites More sharing options...
Tourniquet Posted May 11, 2009 Author Share Posted May 11, 2009 any idea what it is or you not solved it yet either ? Quote Link to comment Share on other sites More sharing options...
GreaseMonkey Posted May 11, 2009 Share Posted May 11, 2009 Just a thought. But I think it may be the climate control "Room temp sensor" which lives behind what looks like a tiny vent, in the trim panel on the left side to the steering column. It may be unplugged as noticed similar symptoms on a customers car at work to which caused the fault in Question. (But just a thought though, ) Quote Link to comment Share on other sites More sharing options...
SimonB Posted May 11, 2009 Share Posted May 11, 2009 If you do a search for air con diagnostic you will find the procedure for doing a diagnostic check on the air con which will tell you what it thinks is wrong. Quote Link to comment Share on other sites More sharing options...
Tourniquet Posted May 12, 2009 Author Share Posted May 12, 2009 thanks all Quote Link to comment Share on other sites More sharing options...
