AlexJames Posted May 9, 2009 Share Posted May 9, 2009 Been reading a few articles and I am still not 100% sure on the GAIN on my boost controller. When I brought the car it was already fitted and was set at maximum... I am assuming this means that the waste gate stays closed for a maximum amount of time? I read this can also cause over boost? Is over boost, or boost spike still possible when I have a 1.2 restricter ring fitted? If it DOES, then how do I know where to set the GAIN? Quote Link to comment Share on other sites More sharing options...
ShamelessTT Posted May 9, 2009 Share Posted May 9, 2009 (edited) What boost are you getting now??? Turn boost controller OFF and you should get nearish stock boost (i get 0.9bar, with BC off fully decatted with nur spec rx exhaust). Your gain shouldnt be that high, either the restrictor ring is way to small or you exhuast system is too restrictive. (Failing that i guess turbo condition will come into it). Without knowing what boost your actually getting, its impossible to say..... My gains on 64 at the moment and thats about 1.1 - 1.2bar (depends on air temp, when cold its 1.2, warmer and its 1.1 which id say is a good safe medium) 1. You can still over boost with 1.2bar restrictor ring (or atleast i could!) 2. Without the right settings on BC, mine was spiking all over the place You only raise your gain, when you getting Edited May 9, 2009 by ShamelessTT (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted May 9, 2009 Share Posted May 9, 2009 Which b/c are you using, on the blitz its the set feature which raises the boost and the gain feature allows the turbo/s to come in harder, in the manual it says dont go above 25 gain with stock turbo`s as it can break them. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 9, 2009 Share Posted May 9, 2009 To kind of answer all your questions, you need a boost gauge. There is no hard and fast rule of what settings are best as every car seems different, there are so many variables that contribute to what boost levels your car will output with certain settings. For example, when I picked up my car,in warm weather, set to 60 will boost to 1.3bar with the 1.2 ring in place. First thing I did was lower it so it never goes over 1.2 A boost gauge will tell you what your car is boosting too, once you know this, you'll know where to set the boost controller. Quote Link to comment Share on other sites More sharing options...
AndyT Posted May 9, 2009 Share Posted May 9, 2009 I am wracking the brain. I got a great explanation the other day but can't remember what I was searching. It's not simple, I know that. Quote Link to comment Share on other sites More sharing options...
ShamelessTT Posted May 9, 2009 Share Posted May 9, 2009 No boost gauge = cardinal sin of BPU modding = failing turbos Quote Link to comment Share on other sites More sharing options...
AndyT Posted May 9, 2009 Share Posted May 9, 2009 You alter lo and hi boost when you alter gain. So it's not a simple job. The only guide I can find now says you need to lower gain if you get boost spikes. Until you don't get the spikes and everything stabilises. I'll keep looking bud. Quote Link to comment Share on other sites More sharing options...
AlexJames Posted May 9, 2009 Author Share Posted May 9, 2009 Thanks guys for your comments, im propper confused at the moment with some FCD issues.. Ill start a thread on that.. Ooh and to answer the questions, I have an SARD Boost controller with gauge, I will post a pic in a bit. Quote Link to comment Share on other sites More sharing options...
AlexJames Posted May 9, 2009 Author Share Posted May 9, 2009 Setting one = 0.8 Bar Setting two = 1.2 Bar Quote Link to comment Share on other sites More sharing options...
