Chris Wilson Posted October 20, 2002 Share Posted October 20, 2002 Originally posted by ashleywillis Ok, I will put my hands up, have been reading the gauge slightly wrong, am hitting 1.2 bar, Chris.......views...!!! It was the spacing of each digit. No worries, easily done :-) Quote Link to comment Share on other sites More sharing options...
michel lane Posted October 21, 2002 Share Posted October 21, 2002 anyone knows what 1.37bar equals to psi? Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted October 21, 2002 Share Posted October 21, 2002 Originally posted by michel lane anyone knows what 1.37bar equals to psi? Approx 20psi. Quote Link to comment Share on other sites More sharing options...
michel lane Posted October 21, 2002 Share Posted October 21, 2002 thanks for that Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted October 21, 2002 Share Posted October 21, 2002 is 1.4 bar still too much to run with a front mount intercooler and water injection? is it the heat that kills turbos or just overboosting highest i have hit is 1.4bar with cw pipes not fitted fmic yet and was going to get water injection to bring temps down Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 21, 2002 Share Posted October 21, 2002 Originally posted by MONKEYmark is 1.4 bar still too much to run with a front mount intercooler and water injection? is it the heat that kills turbos or just overboosting highest i have hit is 1.4bar with cw pipes not fitted fmic yet and was going to get water injection to bring temps down At 1.4 bar stock turbos will be overspeeding badly, and the charge air temps will be dangerously high, especially as most stock intercoolers are now falling apart (news on a fix soon...). It really needs reducing to about 1.2 bar max. Quote Link to comment Share on other sites More sharing options...
Justin Posted October 21, 2002 Share Posted October 21, 2002 Originally posted by Billy that sounds possible ill take the ties off and try it.if there is any one else with a simular set up can you please post what boost you are making I have Blitz Nur Spec, TRL FCD, CW Down pipe and HKS mid de-cat pipe. I have hit 1.45 bar in the summer! Quote Link to comment Share on other sites More sharing options...
Billy Posted October 22, 2002 Author Share Posted October 22, 2002 chris if i get you to fit an uprated side mount intercooler and water injection what then woud be the max safe boost you can run on a j spec with stock fueling and turbo's Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 22, 2002 Share Posted October 22, 2002 Originally posted by Billy chris if i get you to fit an uprated side mount intercooler and water injection what then woud be the max safe boost you can run on a j spec with stock fueling and turbo's 1.2 bar still, but with more safety than without WI and a knackered stock I/C. The turbo speed will be similar. Overspeeding is the killer of the turbos, heat is the engine killer (comustion heat and det that it causes). Quote Link to comment Share on other sites More sharing options...
Billy Posted October 22, 2002 Author Share Posted October 22, 2002 Cheers Chris. as you know I am currently making 1 bar how accurately can you achieve 1.2 bar by fitting a bleed t can you set it spot on or will ambient air temp affect it making you have to constantly adjust it Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 22, 2002 Share Posted October 22, 2002 Originally posted by Billy Cheers Chris. as you know I am currently making 1 bar how accurately can you achieve 1.2 bar by fitting a bleed t can you set it spot on or will ambient air temp affect it making you have to constantly adjust it I have never had a problem with ambient air making a noticeable difference to boost pressure. A good valve will allow you to set + or - 0.5 psi easily. They are FAR less hassle than the electronic controllers on sequential turbos, IMO. Quote Link to comment Share on other sites More sharing options...
Billy Posted October 22, 2002 Author Share Posted October 22, 2002 Sounds good to me How much are they and can you supply them Quote Link to comment Share on other sites More sharing options...
