Boost Pressure
Billy
Well I have finally done it. fitted my two cw down pipes and a blitz nur spec, hks boost gauge, and trl fuel cut defender to my j spec tt auto. taken it for a few fast runs with the nur spec baffle both in and out right up past five grand in top gear but I cant get the boost to go above 1 bar I have tried at all different times of day to see if air temp makes a difference but get the same result every time, bang on 1 bar I spoke to cw and he said he thought it should make about 1.1 to 1.2 bar ive cheeked all hoses etc but all seem ok just wondered if anyone on the board had had a similar result after doing a full de cat
Billy
Billy
Have you checked the boost against another gauge, in case the new one is faulty? Where are you measuring the pressure from Bill?
Hi chris
I'v got the gauge you supplied sitting in my garage. I whent to see Justin a couple of weeks ago, to get some clear front indicators, when i was there he showed me a nice new HKs mechanical boost gauge. (I could n't resist it) so his mecanic fitted it in place of the existing clock while i was there. Looking under the bonnet it would appear that he has teed it in to a black hose close to the bulk head on the throttle side of the car. It just does n't seem to boast above 1 bar no matter what the ambient air temp is. Not worried about this, just wondered if it was normal.
Regards
Billy
Hi chris
Regards
Billy
See if you can jury rig up my boost gauge to see if they agree on the boost figure, ideally T them together so they both indicate.
You should try and run the gauges direct off the manifold plenum, after the throttle bodies. It may well be like that already, hard to say without looking or seeing a close up photo. I am still a little surprised it isn't showing more boost though.
Billy
hi billy
you have same set up as me blitz nur spec and both cw pipes and trl fuel cut
i have a j spec auto too and hitting 1.2 - 1.3 with no problems
i have the hks 60mm electronic boost gauge,it is plummed into the same place as yours too,will take a pic tommorow see if yours is same place as mine.got it on a t pipe
its weird you got all same spec of parts as i have on my car
hope ya get it sorted.
mark
I am in a similar position to you with low boost even though I have a CW pipe and HKS front pipe (with FCD).
(Chris - not spoken to you yet about this but want to finalise testing before I do)
I run about 0.9bar most of the time although i haven't really taken it on a major test run yet (trying different temps etc).
I was hoping for at least 1.2 on a cool day.
CW installed the Cat removal pipes and the boost pipes ready for me to install a guage in the clock mount which is what I have done with no problems (apart from this of course).
Maybe there is a leak similar to yours. Obviously the piping is correct (coz CW did it) but maybe its loose behind the guage.
I will update after further testing
i have now cheked all the pipes for leaks and re piped the boost gauge it was teed into the vacume servo pipe i have now teed it in to were cw advised me to [thanks for all youre help chris] but still only hitting max 1 bar the car is only a weekend toy and has only done 20k miles i am now wondering if its just a matter of having a particularly good waste gate that is flowing enough to keep the boost down
Originally posted by ashleywillis
Guys,
On you boost reading Im feeling a little pleased then, I have a CW down pipe on a HKS Hyper exhaust, with a fule cut defender and I have hit a max of 1.6 bar....:p
Ouch! I would get that fixed quick, not good for the engine or the turbos!
The Nurspec and the ARC pipe I have fitted are both 80mm (3 inches) diameter piping, in comparison to some of the HKS pipes that are 95mm (3 1/2 inches) With the boost controller off I only get about 1.05bar max, could this have something to do with the slightly smaller pipe diameter?
I have Blitz exhaust, HKS mid pipe and CW down pipe. My max has been 21.4 psi (1.45 bar). I have just taken delivery of a CW restrictor ring to get pressure down to a less potentially catastrophic level.
I shall be fitting it real soon before my turbo blades exit through my exhaust!
More probably the ARC system is more restrictive than some others.
Did the new crank trigger fix your misfire?
  • 2 weeks later...
Originally posted by Chris Wilson
That's ludicrously high and needs reducing before it dets to destruction!!
Ok, I will put my hands up, have been reading the gauge slightly wrong, am hitting 1.2 bar, Chris.......views...!!! It was the spacing of each digit.:stupid:
