Help identifying gearbox v160/v161
jevansio
I always assumed being facelift that I had a v161, but if I put in v160 everything becomes clear, the speeds in each gear, the fact my car rattles through 1-5 and hit a brick wall in 6th on the VMax day compared to my mates 911
It tells you on the vin plate which gearbox you have.
Mine is:...... Trans/Axle...... V161....AO3B
A typical vin plate.
You could always jack the rear up and turn the engine over by hand to check the gearbox/diff ratios.
Edited by merckx (see edit history)
Mystery solved, cheers Merckx, my VIN plate shows V160, so I've got a non-vvti facelift with v160 & the facelift diff :)
So this confirms why I need to grab 5th for 130, also the car is technically 200mph capable again :D
Guest drlee
i got v160 with torsen,whats that good for,,any ideas?last i had before i remembered what i was doing was 184 mph at about 5600 rpm,that was before i sorted my brakes.. d
Good to know the trans calculator is coming in handy :D
