Thinking of going single
Andre
A few bits to consider, with very ROUGH prices off the top of my head, so not that accurate, but add it up.
Turbo kit £4K
Midpipe and exhaust £600
Intercooler £1200
Fuel Kit £1200
ECU, £1K
Wideband £250
Mapping £600
Clutch £500
iridium plugs £80
decent Oil cooler £200
BOV £150
fitting costs £?????
options
billet timing belt bracket £150
Kevlar belt £80
cams £600
TRD LSD so it puts the power down. £550
Not so optional - Better brake pads, £160 to £400
Good guidelines but that 1200 for the intercooler is ott imo, would get top class i/c for that money yes but for about 400-500 he will be able to find a good one more than capable of dealing with 550+hp
Turbo kit £4K
Intercooler £1200
Fuel Kit £1200
ECU, £1K
Wideband £250
Mapping £600
Clutch £500
iridium plugs £80
BOV £150
Not to far away from what i have spent so far without my turbo kit. I guess you could of done it cheaper a year ago...crappy exchange rate now:(
Single builds aren't cheap, if you want a reliable engine and single build that will last a long time it's worth spending the money to get it all done properly.
Mine cost around £13k in total, i think, but i went the route of having the engine's internals modified too, which most people don't do. I'd budget around £10k like most people have said.
Ok thanks it will have to wait a bit longer than i thought. The curse of the soop,more power more power!
not bad this is my spec to get what ive spent, but the turbo, intercooler, exhaust bits, and wastegate i managed to get from buying a supra with a nackered engine
GT4088 single turbo
boost logic auto drag box
3800 high stall torque converter
hks 264 cams
greddy emanage ultimate ecu
wiseco forged pistons
sard 800cc fuel injectors
LSD
hks fuel cut defencer
hks ssqv (dump valve)
moddified fuel rail for twin feed
2x walbro fuel pumps
gear box rad
hks advanced timing pullys
gates racing cam belt
new toyota oil pump
new toyota water pump
all new engine bearings
all new engine gaskets
ARP head stud kit
polished rad pipe
polished intake manifold
3 core front mount intercooler
44mm tial waste gate
aeromotive fuel pressure regulator
blitz boost controller
custom intercooler pipes
custon down pipe
custom mid pipe
screamer pipe
Guest drlee
he,is that me? with all due respect,i dont mean to annoy anyone,but power does not always need a powerfull wallet,i appreciate that some need instruction ,but some people chuck them,and enjoy building thair own gear,i think its called throwing ur arse to the wind!.im sure most of u have grabbed ur seat with ur arse.funny but sometimes costly. d.r
well power come with sensible engine upgrades, pushing big power though a stock engine altho can be done i wanted to play safe. as with my gear box, would of been cheaper to keep my stock auto box, but blowing every 5 mins would eventualld add up to a lot more
