johnd-mkiv Posted May 5, 2009 Share Posted May 5, 2009 Been looking into putting a set of 2jz cams into my 1jz head with little machine work they will fit. I still have a pair of j spec cams from my old supra in he shed, the write ups are mainly from across the pond, they are using the us cams over j spec. Just wondering the gains i would get from using an inlet cam from a uk spec over my j spec, I have found the following info on here but dont have any to hand on the 1jz cams. he UK spec intake cam has slightly longer duration, higher lift compared to the J-spec, the exhaust cams are identical. J-spec Cam Specs Intake Cam - 224°, 7.88mm lift Exhaust Cam - 233°, 8.4mm lift UK Cam Spec Intake Cam - 233°, 8.25mm lift Exhaust Cam - 233°, 8.4mm lift Link to comment Share on other sites More sharing options...
Matt Harwood Posted May 6, 2009 Share Posted May 6, 2009 About 5 hp gain across the top of the rev range and peak power coming in about 400 rpm later. We tried it years ago. Link to comment Share on other sites More sharing options...
johnd-mkiv Posted May 6, 2009 Author Share Posted May 6, 2009 (edited) About 5 hp gain across the top of the rev range and peak power coming in about 400 rpm later. We tried it years ago. Thanks was this using j spec cams or uk cams? I take it this was in a 1jz too done a bit of research on the 1jz stock cams 224 (in) 228 (ex) Edited May 6, 2009 by johnd-mkiv (see edit history) Link to comment Share on other sites More sharing options...
Matt Harwood Posted May 6, 2009 Share Posted May 6, 2009 That was changing from JDM cams, to UK spec on the 2JZ. So, looking at the 1JZ cam durations, you may get another couple of HP as the exhaust cam is also different. Link to comment Share on other sites More sharing options...
johnd-mkiv Posted May 7, 2009 Author Share Posted May 7, 2009 That was changing from JDM cams, to UK spec on the 2JZ. So, looking at the 1JZ cam durations, you may get another couple of HP as the exhaust cam is also different. Cheers mate think ill hold off until a high lift set turn up Link to comment Share on other sites More sharing options...
bondango Posted May 13, 2009 Share Posted May 13, 2009 If swapping 1jz cams with UK 2JZ cams There is an additional .55mm lift on the intake and additional 1.06mm lift on the exhaust. There is also about 10deg more duration. Machine work needed for both inatke and Exhaust :- Both Intake and Exhaust Cam need to be machined down to accept the 1jz Cam seal. The nose of the 2jz camshaft (that carries the seal) is 2.5mm wider than the 1jz cam After this the Intake Cam will fit ok Now, the exhaust cam needs extra machine work to fit. The 1st Journal on the 1jz cam is 1.5mm longer than that on the 2jz cam. So the journal diameter on the 2jz cam needs to be increased by 1.5mm Link to comment Share on other sites More sharing options...
