Engine turn without iignition
csa
When I change my oilfilter I'd like to turn the engine without ignition to get the oil round the engine and filter before fireing up.
is there a fuse I could pull? (I'm running AEM EMS)
Guest Budz86
Would this work on a stock NA? Need to change the oil soon and want to get it round the engine before starting it up
If you're only doing an oil change, there will still be enough oil on the bores and in the lifters to protect the engine on first start up with new oil. whichever way you look at it, the starter motor's gonna turn the engine over with or without the car starting! Did mine on thursday with no problems! :D
If you really want to do it though, you can pull the king lead off the distributor or disconnect the coil pack.
