martin1982 Posted May 5, 2009 Share Posted May 5, 2009 OK I've spent a good few days reading through the various threads covering smoke coming from the Supra but couldnt find a scenario similar to whats happening to me. On startup I'm getting a puff of blue smoke (which seems to be an indicator of stem seals). It's only on startup and is not constant. If I blip the throttle while on idle I get a puff of blue smoke but then all is normal again. Got a mate to follow me to see if I get any smoke while running under load, get no smoke when I accelerate hard or gently and no smoke when sitting in traffic. However, whenever I came off the throttle to slow down or just come off boost from accellerating hard there was a puff of grey/black smoke which seems to indicate over fueling. Any ideas what I could be looking at? Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted May 5, 2009 Share Posted May 5, 2009 Valve stem seals. Blue smoke on startup and smoke when lifting off and over-run would say stem seals to me. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 5, 2009 Share Posted May 5, 2009 Did the smoke start to manifest once you went BPU by any chance? decat + free flow exhaust will show up weak/failing turbo seals, if progressed you will get smoke on hot idle, and you will see smoke on closed throttle/overrun. Link to comment Share on other sites More sharing options...
bodilx6 Posted May 5, 2009 Share Posted May 5, 2009 I've got exactly the same. After reading up on this for a year or so both here and on supraforums, I've concluded that its most likely the valve stem seals. But when talking to other people with experience they have told me both. When asking Chris Wilson, he told me that it really is too hard to tell for certain. Probably the best bet is to get both things done at the same time. Valve Stem are not a big problem when having everything apart anyway. They are harder to two but possible without removing the head, but choose this only and you might end up with a car still smoking... Its a hard one, which is why I haven't gotten it done yet. Also I would like to stay with the stock turbos, and then its rather a large and troublesome thing to do just for some smoke.. Link to comment Share on other sites More sharing options...
martin1982 Posted May 5, 2009 Author Share Posted May 5, 2009 Went BPU last June and it's only recently that there has been smoke, think I first noticed it about 2 weeks ago. Link to comment Share on other sites More sharing options...
Guest drlee Posted May 8, 2009 Share Posted May 8, 2009 valve stems dude,mine never smoked till i changed my engine last weekend,same turbo back on there.exactly the same symptoms you r having,its not my turbo.hope this saves you some. d Link to comment Share on other sites More sharing options...
martin1982 Posted May 14, 2009 Author Share Posted May 14, 2009 Yeah thats what I thought. Just need to find someone to carry out the work for me. Heard there's a guy at AFR Tuning that does it cheaper than most garages! Link to comment Share on other sites More sharing options...
Guest drlee Posted May 17, 2009 Share Posted May 17, 2009 i could sort it for you,d Link to comment Share on other sites More sharing options...
martin1982 Posted May 18, 2009 Author Share Posted May 18, 2009 i could sort it for you,d you have pm! Link to comment Share on other sites More sharing options...
adnanshah247 Posted May 18, 2009 Share Posted May 18, 2009 how much does it cost to get the valve stems done? mine is doing the same Link to comment Share on other sites More sharing options...
oxi83 Posted May 18, 2009 Share Posted May 18, 2009 Depends on your garage. After asking around a little bit, I got around £600 in average... Doing this yourself isn't that hard, there are some good diy's on here ;-) Link to comment Share on other sites More sharing options...
