Smoke.
martin1982
OK I've spent a good few days reading through the various threads covering smoke coming from the Supra but couldnt find a scenario similar to whats happening to me.
On startup I'm getting a puff of blue smoke (which seems to be an indicator of stem seals). It's only on startup and is not constant. If I blip the throttle while on idle I get a puff of blue smoke but then all is normal again.
Got a mate to follow me to see if I get any smoke while running under load, get no smoke when I accelerate hard or gently and no smoke when sitting in traffic. However, whenever I came off the throttle to slow down or just come off boost from accellerating hard there was a puff of grey/black smoke which seems to indicate over fueling.
Any ideas what I could be looking at?
I've got exactly the same. After reading up on this for a year or so both here and on supraforums, I've concluded that its most likely the valve stem seals.
But when talking to other people with experience they have told me both.
When asking Chris Wilson, he told me that it really is too hard to tell for certain.
Probably the best bet is to get both things done at the same time. Valve Stem are not a big problem when having everything apart anyway. They are harder to two but possible without removing the head, but choose this only and you might end up with a car still smoking...
Its a hard one, which is why I haven't gotten it done yet. Also I would like to stay with the stock turbos, and then its rather a large and troublesome thing to do just for some smoke..
Guest drlee
valve stems dude,mine never smoked till i changed my engine last weekend,same turbo back on there.exactly the same symptoms you r having,its not my turbo.hope this saves you some. d
