Jetwashed engine problem
Blackie
NA per chance?
You probably find water has dropped into the gulley by the plugs, it doesn't really dry out.. you need to get an airline in there and blow the majority out.
ahhh! didnt think of that one
NA per chance?
So where would i stick the air line? Where the leads go in? Have i got to take anything off?
As you look at the engine, between the two cams... ;)
Erm, you sort of need to take the inlet section that runs over the top of the engine off to get access. Not overly difficult, couple of bolts. There is an addition plate that sits in the gulley that you will have to remove, and then start blasting :)
As you look at the engine, between the two cams... ;) REEEAAALLLYYYYY :sly:
Bugger, Its more work than i wanted to do but i suppose i have too. Cheers
