Pig Posted May 3, 2009 Share Posted May 3, 2009 Thought that would get you looking. I have fitted grooved disks and have a knocking noise coming from them. It stops when i touch the brake. Is there something i can do to stop this? As if this is the norm I am going to have to remove them as it sounds terrible. I did think it maybe the pads needed bedding in so i gave them a VERY hard time. That stopped it for a short period but it came back Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 3, 2009 Share Posted May 3, 2009 Sounds stupid, but did the new disk's go on properly? Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 3, 2009 Share Posted May 3, 2009 Rattle pins on the pads not there perhaps? Did you put copper grease on them as well? Quote Link to comment Share on other sites More sharing options...
Pig Posted May 3, 2009 Author Share Posted May 3, 2009 Sounds stupid, but did the new disk's go on properly? Not fitted by me. I would be VERY supprised if it were not correct. Edit: Whats a rattle pin? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 3, 2009 Share Posted May 3, 2009 Hopefully it's not the discs knocking, it's the new pads you should have fitted. There is no way the disc itself could knock, unless you have done something very wrong. Quote Link to comment Share on other sites More sharing options...
Pig Posted May 3, 2009 Author Share Posted May 3, 2009 Hopefully it's not the discs knocking, it's the new pads you should have fitted. There is no way the disc itself could knock, unless you have done something very wrong. Im sure the noise is the pads hitting the groves. Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 3, 2009 Share Posted May 3, 2009 Not fitted by me. I would be VERY supprised if it were not correct. Edit: Whats a rattle pin? It is just a bit of spring metal, but keeps the pad centred in the caliper, so it doesn't bounce up and down. Quote Link to comment Share on other sites More sharing options...
paul mac Posted May 3, 2009 Share Posted May 3, 2009 does it do it under heavy braking, you will get a bit of noise from drilled/grooved discs, i would let them bed in a bit Quote Link to comment Share on other sites More sharing options...
Pig Posted May 3, 2009 Author Share Posted May 3, 2009 does it do it under heavy braking, you will get a bit of noise from drilled/grooved discs, i would let them bed in a bit Nope, its only when there is no brake applied. As soon as i apply the brake the noise stops. Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 3, 2009 Share Posted May 3, 2009 Nope, its only when there is no brake applied. As soon as i apply the brake the noise stops. That is why I said rattle pins, as soon as you use the brakes the pad will be at the top of the caliper and held there by the rotating friction of the disc. Once you release pressure they will drop down again and bounce with the wheel's travel. Quote Link to comment Share on other sites More sharing options...
Pig Posted May 3, 2009 Author Share Posted May 3, 2009 Ah ha, after your advise i have just popped out to the car and there is play in the pads. I assume that means im missing those jibby jobs? Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted May 3, 2009 Share Posted May 3, 2009 I have grooved discs all round, and I don't get any knocking,, as others have said, it sounds like the return springs/clips haven't been fitted Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 3, 2009 Share Posted May 3, 2009 Reminds me of a video one of the Time Attack boys posted up last year. There was a horrible knocking noise that was timed with the road speed. Sounded to me like the alloy was hitting the caliper, but apparently it was something else - have a search. Quote Link to comment Share on other sites More sharing options...
BOB B Posted May 3, 2009 Share Posted May 3, 2009 Hi, Is it more of fast ticking noise that obviously gets quicker as the cars speed does and as you say goes as you brake? The reason I ask is I fitted grooved and dimpled discs with new pads to the front of mine a couple of months ago and with the windows down you could here the quick ticking. I have to say though that mine are getting less noisey as they bed in propperly, but if its a propper knocking sound then it isn't the same. Bob. Quote Link to comment Share on other sites More sharing options...
Pig Posted May 4, 2009 Author Share Posted May 4, 2009 Has anyone got the part number for the rattle pins? Jon Quote Link to comment Share on other sites More sharing options...
AshBhp Posted May 4, 2009 Share Posted May 4, 2009 (edited) Edited May 4, 2009 by AshBhp (see edit history) Quote Link to comment Share on other sites More sharing options...
Pig Posted May 4, 2009 Author Share Posted May 4, 2009 Thanks Ash, really kind to go to that much effort Quote Link to comment Share on other sites More sharing options...
AshBhp Posted May 4, 2009 Share Posted May 4, 2009 Pleasure mate. Quote Link to comment Share on other sites More sharing options...
Guest drlee Posted May 8, 2009 Share Posted May 8, 2009 are they floating disks dude? Quote Link to comment Share on other sites More sharing options...
