Guest rustybolt Posted May 3, 2009 Share Posted May 3, 2009 how do i upload photos of my car for you to see: Quote Link to comment Share on other sites More sharing options...
jamesmark Posted May 3, 2009 Share Posted May 3, 2009 Sign up to http://www.photobucket.com upload pictures, resolution 800 x 600 is ok once that has done copy the URL IMG below the picture in Photobucket. Paste it in a thread. Or copy the direct link into a thread and have it wraped with IMG code i.e. value Quote Link to comment Share on other sites More sharing options...
AndyT Posted May 3, 2009 Share Posted May 3, 2009 This method uses the site to host and produces the larger pics with a thumbnail GarethR -- click on "Go Advanced" -- attach the picture to the post by using the "paperclip" icon, which gives you the thumbnail -- save your post -- right-click on the thumbnail and select Copy Shortcut to copy the URL (in Firefox select Copy Link Location) -- edit the post -- paste the URL and use the IMG tags around it to display the same picture full size as well as the thumbnail Or Jevansio If you want to use this site to host the pic, upload them as attachments as normal (so they would appear small along the bottom), From the current attachments list of uploaded images in the manage attachements window, right click the 1st image & choose copy shortcut, then paste that between the image tags. Repeat for each image (but they're the same link with the id incremented) You'll get one in the main thread & another along the bottom (repeat for each image): From Homer you need to use and tags to insert picture to a thread Alternatively you can use a site like Photobucket to host your pics and copy the img code into your post. Don't forget to resize the pics using this method. Or you can just go to the Manage Attachments under Submit Reply tab and browse to the pics on you computer and upload. They'll appear as thumbnails in post and expand when clicked. Quote Link to comment Share on other sites More sharing options...
