Clutch and Flywheel - advice, experiences and opinons needed
Mike B
I used a stock clutch at BPU for about 3years - no problems or excessive wear but I cannot tell you the exact life.
I also used one of Chris Wilson's clutches at BPU for about 3 years - no problem - CW may be able to give you some idea of life expectancy.
Terry bore out the master cylinder? I'd take that with a pinch of salt from my experience.
The answer to light pedal, smooth engagement, and holding all the power your car can throw at it is the Centerforce dual friction. I have used it in two cars, I can pull away like a hearse, or do burnouts galore, it just keeps holding, and means I can use a stock fly.
Lots of members here use them, even Dimitri an ex HKS triple user. I dont know what the horse power limit is, but I am currently running over 700 (was 664 re dyno shortly) and it works great for me. Not the pricey either. I dont rate RPS at all FWIW.
