Black UK manual Single
dan4
Im going to do it on a spur of the moment, that way i think i may not regret it/change my mind!
AEM dryflow air filter
Heatwrapped intake pipe
HKS Intercooler, HKS hard piping and hosing
Smoothed stock inlet manifold
880cc Precision Fuel Injectors
HKS Fuel rail anodised blue
16mm Fuel feed line, twin 16mm feed to fuel rail
10mm Fuel return line
Aeromotive Fuel pressure regulator
Walboro 255 Fuel pump
NGK grade 8 plugs
HKS DLI Ignition
Precision T67 Turbo with BL braided oil lines
HKS replica tubular manifold
Tial 44mm External wastegate with 2inch Screamer pipe
AEM Boost control solenoid
Boost Logic downpipe and mid pipe with AEM wideband Air/Fuel Ratio Sensor
HKS SuperDragger Intermiediate and rear exhaust 5inch slash cut
Stock bottom end
Rebuilt stock Cylinder Head
3 angle valve grind
New valve guides
Re shimmed
Secured with ARP Racing head studs and fasteners
Stock Metal 3 layer Headgasket
New stock flywheel
RPS 6 Paddle Max Sport Clutch
Stock gearbox
LSD
17inch Rays Cerumo Split rims
Powder coated Black centres, polished rim
235/45/17 front
255/40/17 rear
Whiffbitz Front Bumper, black mesh with red TRD logo
CW racing brake pads
Stock skimmed discs
High performance brake fluid
Street setup Laser wheel alignment
AEM EMS full standalone ecu mapped by Ryan G to 520bhp/490ftlb at 1.4bar
Switchable boost maps 1.1bar and 1.4bar
Launch control with anti lag
AEM Wideband Air/Fuel Ratio gauge
Burton Power Boost gauge
GloShift fuel pressure gauge(not fitted)
I wont leave my cd player in but sub and amp is staying;)
Kicker Comp 10inch sub
Toxic 600watt Amp
Full cream leather interior with...
OMP Racing 4point Harness's
126k miles with a hard file full of reciepts, probably every part replaced is in there:rolleyes:
Taxed to end of AUG 2009
MOT until FEB 2010
Been an owners club car for 5years now, used to belong to Zed
Probably best person to comment on this recently would be Ryan and the lads at the eastbourne meet:search:
Any checks welcome
£12,795
Contact me via pm or contact TheRaven/Gaz1 on here for my telephone mumber
  • Replies 54
Madness,
This car is mint and Dan has spent big money and lots of time getting this to run perfect.
Ultra clean
Serviced to the max
I would say good luck with the sale, but your selling us out! Unless of course you get another one
I suspect this car is too modified for France, so it might stay in the UK!
I have viewing arranged not sure whether im happy about that or not :(
If it doesnt go to France i suspect it will go to Denmark/Holland as there is good interest from there also
  • 3 weeks later...
