jevansio Posted May 12, 2009 Share Posted May 12, 2009 Darryl I went to take a photo of mine at the weekend, but my diffuser blocks it completely now, I'll get my VIN code today Quote Link to comment Share on other sites More sharing options...
Guigsy Posted June 10, 2009 Share Posted June 10, 2009 very usefull I've put together an Excel file which shows the effect of fitting various sized diff and gearboxes to the supra, it also contains a graphical chart showing the effect different tyre & wheel sizes and offsets effect both fitment to the hub and the effect on speed/acceleration. There are two main sheets on the file, Wheel size fitment and gear ratio calculator. Before it goes to the tech reference section, can some of you please review it and see if there are any errors or faults? Also, any suggestions for enhancement are welcome It took a silly amount of time to research the data and put this together, so hope it's going to be useful to someone Edit - updated with "final" version.. Quote Link to comment Share on other sites More sharing options...
Homer Posted June 10, 2009 Author Share Posted June 10, 2009 Thanks for the reminder Guigsy, need to update this to the last and hopefully final version Its the normal code isnt it :- Crown Wheel Size: A (8'' - 203mm), B (8.7'' - 221mm) Differential Ratio: 01 (4.083:1), 02 (3.769:1), 03 (3.267:1) Differential Type: A (Standard open differential), B (Torsen LSD) Wes, you (and Digsy) were right all along, the above codes are correct I'll try and sort out the last version this week and upload to the tech section. Sorry for the confusion, my mistake entirely. Quote Link to comment Share on other sites More sharing options...
Batmax Posted August 1, 2009 Share Posted August 1, 2009 So and the driveshafts anyone knows, because I broke my aluminum diff cover and broke my driveshafts now i don't know if the uk auto diff + driveshafts will work on my supra ? Also I want buy an new cover because these auto diff have cooler Quote Link to comment Share on other sites More sharing options...
Homer Posted August 26, 2009 Author Share Posted August 26, 2009 Final bump before posting this in the tech section Any errors, improvements or other suggestions? Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 4, 2009 Share Posted October 4, 2009 (edited) i know its a bit late but any possiblity of adding TRD diff specs into this unless there the same ratios as stock?? Edited October 4, 2009 by Kirk (see edit history) Quote Link to comment Share on other sites More sharing options...
Homer Posted October 4, 2009 Author Share Posted October 4, 2009 i know its a bit late but any possiblity of adding TRD diff specs into this unless there the same ratios as stock?? The ratios are the same as stock Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 16, 2012 Share Posted June 16, 2012 (edited) Can somebody that can work this calculator do me a favour. Put in:- 8300rpm limit. 28" tyre UK auto diff which is 3.769 i think. V160 gearbox Just trying to work out what sort of speed i could do in 4th gear with that setup? cheers. Edited June 16, 2012 by JamieP (see edit history) Quote Link to comment Share on other sites More sharing options...
mattdavies Posted June 16, 2012 Share Posted June 16, 2012 (edited) Whats your exact tyre size ? i used 255/40/18 to get a 28" diameter This give you at 8200 in 4th gear 128.4 MPH Edited June 16, 2012 by mattdavies Worked it out (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 16, 2012 Share Posted June 16, 2012 Whats your exact tyre size ? i used 255/40/18 to get a 28" diameter This give you at 8200 in 4th gear 128.4 MPH 325/50/15 Thanks, Looks like the auto diff is no good even with big drag tyres, i wont be trying that now. Quote Link to comment Share on other sites More sharing options...
DARETT Posted June 16, 2012 Share Posted June 16, 2012 It makes the car feel faster, and it could possibly be on the road, but will slow you right down on the drag strip Quote Link to comment Share on other sites More sharing options...
Pig Posted June 16, 2012 Share Posted June 16, 2012 No good for what mate? 200mph run, nope but drag racing I was find IMO. I ran an 11.8 with 600 Quote Link to comment Share on other sites More sharing options...
JamieP Posted June 16, 2012 Share Posted June 16, 2012 Yeah, i thought it might work better with the smaller turbo, was hoping it would be around 140mph in 4th, change into 5th will kill the time. Quote Link to comment Share on other sites More sharing options...
