jevansio Posted April 30, 2009 Author Share Posted April 30, 2009 (edited) These are pretty tight, but there are XL versions of the SPG BTW going with some 30mm x 30mm x 3mm 304 stainless steel for the bars (cheers Scott ) from here: http://www.metals4u.co.uk/index.asp Edited April 30, 2009 by jevansio (see edit history) Link to comment Share on other sites More sharing options...
Scott Posted April 30, 2009 Share Posted April 30, 2009 These are pretty tight, but there are XL versions of the SPG BTW going with some 30mm x 30mm x 3mm 304 stainless steel for the bars (cheers Scott ) from here: http://www.metals4u.co.uk/index.asp 304 will be absolutely fine bud. Will look great, shame to cover them up. Link to comment Share on other sites More sharing options...
jevansio Posted April 30, 2009 Author Share Posted April 30, 2009 304 will be absolutely fine bud. Will look great, shame to cover them up. I've prolly spent more than it cost to get 2 bride subframes now Link to comment Share on other sites More sharing options...
Scott Posted April 30, 2009 Share Posted April 30, 2009 I've prolly spent more than it cost to get 2 bride subframes now Lesson learned Link to comment Share on other sites More sharing options...
jevansio Posted April 30, 2009 Author Share Posted April 30, 2009 Lesson learned I've kept quiet about the bit where I hacked the recaro sidemounts as I thought they didn't lean the seat back far enough, then I noticed I had them on back to front , 1 more set of side mounts on order Link to comment Share on other sites More sharing options...
Scott Posted April 30, 2009 Share Posted April 30, 2009 Not going to be taking this on as a sideline then Link to comment Share on other sites More sharing options...
jevansio Posted May 9, 2009 Author Share Posted May 9, 2009 I started the job of refitting my seats using the 3mm steel today, what a PITA this is to drill!!!!! Ended up f*cking up 2m of the stuff, and a set of drills, so at the mo I'm left without any seat. Just ordered some 5mm aluminium and some new aluminium recaro side mounts to match, wish I'd just bought the f*cking bride frames from whiffin at the mo Link to comment Share on other sites More sharing options...
Trig Posted May 9, 2009 Share Posted May 9, 2009 Nice seats they are, dare i ask how much? Link to comment Share on other sites More sharing options...
jevansio Posted May 9, 2009 Author Share Posted May 9, 2009 Nice seats they are, dare i ask how much? Cheers Adam, the seat was £175 + £150 for a new cover set as the original was a little worn Link to comment Share on other sites More sharing options...
Scott Posted May 9, 2009 Share Posted May 9, 2009 I started the job of refitting my seats using the 3mm steel today, what a PITA this is to drill!!!!! Ended up f*cking up 2m of the stuff, and a set of drills, so at the mo I'm left without any seat. Just ordered some 5mm aluminium and some new aluminium recaro side mounts to match, wish I'd just bought the f*cking bride frames from whiffin at the mo If you want to send the stainless down to me i can drill it for you in the work? It is a bit of a pain to drill as you need good drills and a decent amount of weight behind it to get it to cut. To be fair though that just shows how tough it is Link to comment Share on other sites More sharing options...
jevansio Posted May 9, 2009 Author Share Posted May 9, 2009 Many thanks Scott buddy but I'm going to stick with the thicker aluminium. I managed to drill about 16 holes but it sure take it out of titanium coated bits (even when going slow with lots of water), if I could have used tungsten carbide bits it may have gone smoother Link to comment Share on other sites More sharing options...
Scott Posted May 9, 2009 Share Posted May 9, 2009 Yeah carbide is pretty much a necessity. Link to comment Share on other sites More sharing options...
jevansio Posted May 22, 2009 Author Share Posted May 22, 2009 Finished the installation tonight. I went with 1/4" aluminium instead of the 3mm steel. The other seat isn't a Profi SPG, it's an Apex SPG, identical shell & weight, different fabric design, I kinda like the asymetry. Just got to kit out the rear with some carpet to match the black front carpet (I'm using some speaker subbox type material) and fit the rear trim & it should be finished inside. Going for the Porsche GT2 type look Link to comment Share on other sites More sharing options...
JamieP Posted September 22, 2009 Share Posted September 22, 2009 Looks good mate, i have mine on the bride runners but id like to lower my seats, do you think it would be possible to bolt the side pods directly to the floor or is the floor to uneven? Link to comment Share on other sites More sharing options...
jevansio Posted September 22, 2009 Author Share Posted September 22, 2009 Looks good mate, i have mine on the bride runners but id like to lower my seats, do you think it would be possible to bolt the side pods directly to the floor or is the floor to uneven? The floor is too uneven as it stands, I recall seeing a pic of the floor somewhere (maybe Ryans thread), & you could see the mounting points. Anythings possible, but bolting direct to floor (with custom mounts) you'll forgo any adjustment (I don't mind as there's only me drives my car & the passenger seat is mounted as far back as it'll go to cater for even the tallest passenger) Link to comment Share on other sites More sharing options...
JamieP Posted September 22, 2009 Share Posted September 22, 2009 Thought that might be the case, i dont care about being able to move the seat, just want it a bit lower, might take the carpet out and see if i can do something with my mounts, i have a good fabricators up the road from me, cheers mate. Link to comment Share on other sites More sharing options...
Trig Posted September 22, 2009 Share Posted September 22, 2009 looks spot on mate Link to comment Share on other sites More sharing options...
miko_supra Posted December 2, 2009 Share Posted December 2, 2009 This has just inspired me to make up some of my one seat brackets. I was torn between £400 brides or £120 recaro universal (including some fabrication.) But I think I should be ok with some steel I have in the garage to make a fixed position seat. Link to comment Share on other sites More sharing options...
GazzaGSi Posted December 2, 2009 Share Posted December 2, 2009 Didnt notice this thread before, they look great nice work. Do the seats not feel titled too far back? They look like you'd be almost facing the roof when sat in or is it just the perspective from the camera? Looks awesome Link to comment Share on other sites More sharing options...
johnny g Posted December 2, 2009 Share Posted December 2, 2009 Jay's a very laid back character! Link to comment Share on other sites More sharing options...
hodge Posted December 2, 2009 Share Posted December 2, 2009 Jay's a very laid back character! You can say that again especially after 4 bottles of wine. Link to comment Share on other sites More sharing options...
jevansio Posted December 2, 2009 Author Share Posted December 2, 2009 Lol, cheers guys Gaz, it's prolly just the perspective, but I do like my seats laid back a little, once you're sat in them it's a very nice driving position Link to comment Share on other sites More sharing options...
miko_supra Posted December 2, 2009 Share Posted December 2, 2009 Lol, cheers guys Gaz, it's prolly just the perspective, but I do like my seats laid back a little, once you're sat in them it's a very nice driving position How are you getting on with that 2mm ally? Has it lasted ok? Link to comment Share on other sites More sharing options...
jevansio Posted December 2, 2009 Author Share Posted December 2, 2009 I replaced it straight away with 1/4" aluminium Mike (didn't want to take any chances) Link to comment Share on other sites More sharing options...
jmcc42uk Posted July 19, 2011 Share Posted July 19, 2011 (edited) Moved Edited July 19, 2011 by jmcc42uk (see edit history) Link to comment Share on other sites More sharing options...
