Steviekid Posted April 30, 2009 Share Posted April 30, 2009 i gotta find some way to make it chatter on the twin turbo.. maybe open the BOV to the extreme.. That would do the exact opposite to what you want. As we've already said the "chattering" noise is made because the diameter of the BOV is not big enough to let all the back pressure away (from a single turbo) therefore the turbo stalls, exaclty what a BOV is designed to prevent. Link to comment Share on other sites More sharing options...
Guest n0Odle Posted April 30, 2009 Share Posted April 30, 2009 (edited) That would do the exact opposite to what you want. As we've already said the "chattering" noise is made because the diameter of the BOV is not big enough to let all the back pressure away (from a single turbo) therefore the turbo stalls, exaclty what a BOV is designed to prevent. oh.. so that whistle chattering sound is because of a bad set up? i assume turbo stalling is bad right? bov sound of this supra is because he has a bad set up? but i thought this was normal for all supras to have that whistle whomp sound Edited April 30, 2009 by n0Odle (see edit history) Link to comment Share on other sites More sharing options...
Steviekid Posted April 30, 2009 Share Posted April 30, 2009 oh.. so that whistle chattering sound is because of a bad set up? i assume turbo stalling is bad right? It's not a bad setup. Basically, most single turbos create too much boost for an external wastegate (usually around 50mm) to get rid of. The turbo's themselves are strong enough to withstand the stalling. Link to comment Share on other sites More sharing options...
Guest n0Odle Posted April 30, 2009 Share Posted April 30, 2009 your's is TT.. do you have a video of your car wot? Link to comment Share on other sites More sharing options...
Scott Posted April 30, 2009 Share Posted April 30, 2009 It can be bad but only when getting up to high boost pressure. IIRC it only starts to get bad after 2bar. Link to comment Share on other sites More sharing options...
Steviekid Posted April 30, 2009 Share Posted April 30, 2009 your's is TT.. do you have a video of your car wot? I don't but it doesn't sound anything like the one in your link. And that's with an HKS SSQV (silver insert) Nur spec and decat. Still sounds good iino though!! Link to comment Share on other sites More sharing options...
Guest n0Odle Posted April 30, 2009 Share Posted April 30, 2009 im trying to find other sites other than youtube to listen to the sounds of the different inserts Link to comment Share on other sites More sharing options...
Guest n0Odle Posted April 30, 2009 Share Posted April 30, 2009 Alrighty! HKS SSQV Purple insert.. i think the silver comes with them already.. but in the event ill buy both and swap it too see what i like best Link to comment Share on other sites More sharing options...
Scott Posted April 30, 2009 Share Posted April 30, 2009 Alrighty! HKS SSQV Purple insert.. i think the silver comes with them already.. but in the event ill buy both and swap it too see what i like best Yeah, silver comes with. Gold and purple are seperate. I don't know if there are any others. Link to comment Share on other sites More sharing options...
Guest n0Odle Posted April 30, 2009 Share Posted April 30, 2009 just cant wait to drive this baby! depressing i cant get the chatter sound... but im sure it still WONT sound like a damn STR4!! which is GREAT... Link to comment Share on other sites More sharing options...
